Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 17, 2025, 08:32:07 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
O S L A 46S engine
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: O S L A 46S engine (Read 1088 times)
Bootlegger
22 supporter
Trade Count:
0
Admiral
O S L A 46S engine
on:
August 09, 2019, 11:31:26 AM »
What is the difference between the O S L A 46 S engine and the regular O S L A (R/C) engine, also how about the O S 702 muffler, is it a good muffler to run the engine in on? Again thanks
Logged
8th Air Force Veteran
Gil Causey
AMA# 6964
Brett Buck
Trade Count:
0
Admiral
Re: O S L A 46S engine
Reply #1 on:
August 09, 2019, 12:05:21 PM »
Quote from: Bootlegger on August 09, 2019, 11:31:26 AM
One has a carburetor, the other has a venturi, otherwise, the same.
Logged
FLOYD CARTER
24 supporter
Trade Count:
0
Admiral
Reply #2 on:
August 09, 2019, 12:28:42 PM »
The OS 46LA seems to be ideal for stunt, and much lower in cost than "custom for-purpose" stunt engines.
The stock OS mufflers are big and ugly, even though they work well. I advise using a tube muffler made by Scott dinger (if you can get one).
Logged
AMA #796 SAM #188 LSF #020
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
O S L A 46S engine
