  • June 19, 2025, 04:01:52 PM
Author Topic: McCoy 35 RH bolrs  (Read 1570 times)
Offline Lyle Spiegel
McCoy 35 RH bolrs
« on: February 18, 2018, 04:15:42 PM »
I have orginal 35 RH in goos shape. Would like to replace cylinder head & backplate with socketheads. What is thread and length i need? Also, what size Philips tip do i need to use so I dont bugger up the original ones?
Same question for Johnson 35 CS.
Lyle Spiegel AMA 19775
Re: McCoy 35 RH bolrs
« Reply #1 on: February 18, 2018, 04:41:15 PM »
   Use a #1 or #2 Phillips screw driver, just test how well it fits and if it feels solid, then crank it loose.  Use a small scale or ruler and measure from the bottom of the head to the end of the shank, and that is the length. No real mystery with USS stuff.
« Reply #2 on: February 18, 2018, 04:58:47 PM »
Rhank you. I have feeling thread might not be 4-40. Maybe 5-40? Hoping some one will verify.
Offline Bootlegger
« Reply #3 on: February 18, 2018, 05:10:47 PM »
 I f memory serves, they are 4-40, try one if you have it..
8th Air Force Veteran
Gil Causey
AMA# 6964
Online Robert Zambelli
« Reply #4 on: February 19, 2018, 04:41:38 AM »
Yes, 4-40.
You can get them from McMaster-Carr.
Stainless if you want.
Offline dennis lipsett
« Reply #5 on: February 19, 2018, 11:35:04 AM »
Don't waste your time with Phillips head when socket screws are available. I redid about a dozen of the McCoy red heads and used them. I also did not use any gaskets but used liquid gaskets and have never had a leak or blown seal. Also you get a slight compression increase. All of them turned into one flip starters.
Most of the McCoy engine I saw were not wore out, just badly maintained.
Dennis
