My #2 plane is a Sig Skyray. It currently has an old OS 25S in it, and I'm having trouble getting it to run right. I understand that it's not really enough engine for the plane, but my aim isn't to win stunt contests -- it's to have a relaxing 'after practice' plane, and something that I can use to teach a beginner, if I should ever get one in my sights.
It seems like it wants to run at 9500 - 10000 RPM on the ground, but if I launch at that speed it leans out. If I launch rich, it either never speeds up, dies in the air, or (every once in a great while) gives me a good run.
I'm running 15% nitro, about 22% total oil content. I'd tell you the venturi size, but I don't know -- its either 3/16 or 11/64, with a 1/8" diameter spray bar (I'll post dimensions the next time I'm in the same building as the plane). Prop is a Top Flight 9-5 wood ('cause that's what I have lots of!).
So -- what should I be looking at changing, to make this run right? Is the above set of behaviors a sign that it needs a smaller venturi? More oil in the fuel? A smaller prop? Something else?
