  • July 08, 2025, 11:52:09 AM
Author Topic: engine run away from inverted  (Read 2792 times)
Offline Louis Keller, Jr.
« on: October 11, 2011, 08:44:10 PM »
my engine (o s 35) runs great at level flight both upright and inverted. (it's mounted inverted in a nobler). with plane flying upright performance is a good classic 4-2. perfect. but when inverted the slightest up attitude the engine runs far leaner thus faster. return to level flight it's back to normal run again. how can i remedy this. no muffler pressure.
Online Dick Pacini
Re: engine run away from inverted
« Reply #1 on: October 11, 2011, 10:39:01 PM »
Lower the tank a bit.
AMA 62221
Offline Allan Perret
  • Proverbs
« Reply #2 on: October 13, 2011, 06:51:26 AM »
Louis, if it still has the same round tank (Sullivan R-4) I put in it, the uniflow tube is fixed on the outboard wall.
Rotate the whole tank CCW looking from front, to lower u-flow about 1/8".
Allan Perret
AMA 302406
Slidell, Louisiana
Tags: engines  tuning
