Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 08, 2025, 09:11:24 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
engine run away from inverted
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: engine run away from inverted (Read 2791 times)
Louis Keller, Jr.
Trade Count:
0
Lieutenant
on:
October 11, 2011, 08:44:10 PM »
my engine (o s 35) runs great at level flight both upright and inverted. (it's mounted inverted in a nobler). with plane flying upright performance is a good classic 4-2. perfect. but when inverted the slightest up attitude the engine runs far leaner thus faster. return to level flight it's back to normal run again. how can i remedy this. no muffler pressure.
Logged
Dick Pacini
25 supporter
Trade Count:
0
Admiral
Re: engine run away from inverted
Reply #1 on:
October 11, 2011, 10:39:01 PM »
Lower the tank a bit.
Logged
AMA 62221
Once, twice, three times a lady. Four times and she does it for a living. "You want me on that wall. You need me on that wall."
Allan Perret
2017
Trade Count:
0
Admiral
Proverbs
Reply #2 on:
October 13, 2011, 06:51:26 AM »
Louis, if it still has the same round tank (Sullivan R-4) I put in it, the uniflow tube is fixed on the outboard wall.
Rotate the whole tank CCW looking from front, to lower u-flow about 1/8".
Logged
Allan Perret
AMA 302406
Slidell, Louisiana
Print
Pages: [
1
Go Up
« previous
next »
engines
tuning
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
