  • July 12, 2025, 09:44:34 PM
Author Topic: What brand has a "HOT" plug and where may I purchase them?  (Read 1180 times)
Offline frank mccune
« on: March 22, 2015, 07:53:35 AM »
      Hello All:
      I am looking to purchase a HOT glow plug and would like to know what brand makes them and where may I purchase some of these plugs.
      I have been directed to use Thunderbolt RC long plugs for Stunt and Sport flying.  Where may I purchase these?
        Tia,
        Frank McCune
Offline Balsa Butcher
  • High Desert Flier
Re: What brand has a "HOT" plug and where may I purchase them?
« Reply #2 on: March 22, 2015, 09:45:19 AM »
In Thunderbolts you are looking for either the 4 stroke and/or the R/C Long. Also check out "merlinglowplugs(dot)biz". Their 2005 and 2010 plugs are the equivelant of the T-Bolt R/C an 4 stroke plugs respectively. No idle bar but it is not noticed an IMHO they last longer than T-bolts.
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #3 on: March 22, 2015, 10:47:51 AM »
Hi frank
Below is a little about Glow Plugs, I carry many brands and the Merlin plugs mentioned earlier also have a hot plug in their line, as well as the McCoy #59
"Plugs  can also be  a  major cause of trouble, and poor runs.  When you first crank the plane, notice if it goes rich and sags slightly when the battery is removed; if so, the plug is normally too cold.  This is  critical to getting a proper Stunt run.
Most plugs are designed to provide a  colder range than we want in C\L aerobatic engines , and you should try to get the right range for the motor.  Many days of testing and much time and expense buying almost every plug on the market has yielded these results ;Thunder Bolt R\C long, T Bolt #3 , T Bolt 4 stroke, Glo Devil RC #300 long,  Enya 3 & 4, Fireball RC long, the Hobby Shack RC long, SIC RC long  a few of the OS hotter plugs and some of the FOX long and  Miracle plugs are best plugs for our use.  In almost all instances, use a long plus, as they will be substantially hotter than the shorts, plus they are deeper in the combustion chamber and this tends to keep things hotter and keeps  the plug elements cleaner.
A lot of times the plug problems show up as rich inside maneuvers and leaner outsides; this happens because gravity and centrifugal force ,forces the oil-fuel charge down on the element on insides, thus cooling the coil and pulls it away on the outside maneuvers, letting it naturally go leaner.  I have seen this problem instantly cured by simply changing plugs. Please  do not be  afraid  to put in a  new  glo plug , or try different types of plugs ."
