Don't remove any bearings.
Put a prop on it, heat up the case to about "spit" hot, and while it is still hot tap on the end of the crank shaft with a mallet to seat the front bearing.
Tighten up the prop again, repeat as required.
You can also tap on the back of the crankshaft to seat the rear bearing. Works better if the rod has been removed.
I have various little delrin tools that fit in the case and have a hole in them to clear the crank pin to make this easier.
I made mine after I saw Henry Nelson install the bearings in one of my N15RV this way.
If this all fails then you might be missing the spacer that was previously mentioned.
I know ideally you would press on the outer races to install both front and rear bearings, but without special tools you do what you can.
Pressing from the inner races this way can (and probably does) lead to damage to balls and races, but in my experience this is not an issue.
(flame suit on
Pat MacKenzie
