Engine basics => Engine set up tips => Topic started by: Kim Mortimore on September 11, 2012, 06:03:08 PM
Title: Engine cutout in the clover
Post by: Kim Mortimore on September 11, 2012, 06:03:08 PM
A friend of mine has an LA46 that runs beautifully after switching from a RoJett .40 muffler to an old OS 762(?) muffler.  Like a lot of guys, he doesn't like the stock E-3030.  With the old set-up he had a lot of pre-ignition.
The only problem with the run now it that it cuts out and then restarts in the vertical leg between loops 2 and 3 of the clover (obviously not a great place for an engine to cut out).  After the clover he gets ~18 laps before the engine quits, so the tank is not near empty in the clover.  The tank is a standard 1 x 2" metal wedge with open uniflow vent terminating about 1/4" in front of the pickup.  The tank is mounted with the rear end about 1/4" outboard of the front to eliminate the stop/start/stop/start oscillation he was getting previously in the last couple laps.  I vaguely recall hearing about this problem some time in the past, but don't recall the solution.  Anyone know what it is?  Thanks in advance.
Title: Re: Engine cutout in the clover
Post by: Jim Oliver on September 12, 2012, 07:35:19 PM
Could it be that the plane slows down so much that the fuel drops away from the pick-up?
Post by: Kim Mortimore on September 12, 2012, 08:09:34 PM
Jim,
My best guess is that you may be on the right track.  Possibly the roller coaster momentum built up in loop 2 slings the fuel upward in the climb so that it decelerates more slowly than the plane and rises above the pickup just long enough to give the pilot coronary arrythmia.
It's obviously not a situation he will want to live with.
Post by: Chris Wilson on September 12, 2012, 08:41:20 PM
If its a good wedge tank then how can the fuel fall away from the pickup? (It is not in a free fall situation.)
And even it was, there is still enough fuel in the lines to cover that part of the schedule even if the tank was to become bone dry.
Just working with what you have said, and that is a muffler change that solved pre-ignition, it sounds like you are now running the engine very much colder and thus need a hotter or shielded plug to compensate for the temporary flame out caused by the fuel being thrown inside of the engine and onto the plugs elements.
Post by: Brett Buck on September 12, 2012, 10:27:48 PM
Jim,
   Make the peak of the wedge a more acute angle, and tilt the back end of the tank a little (or build it with a wedge).  Even a little bit of change makes a big difference. The standard Veco T-21 style is just a little to shallow and tends to do exactly that - the acceleration draws the fuel towards the bottom of the tank, AND, it yaws nose-out which tends to move it further towards the front.
Post by: RandySmith on September 12, 2012, 10:54:23 PM
Brett is right, also what plane is this in? profile or built up? how far is the front of the tank from the back of the engine?
Post by: Chris Wilson on September 12, 2012, 11:43:04 PM
What I don't get with the above explanation is that the tank has 18 laps left in it after the last  maneuver ........... 18!
So if it is a standard tank it must be truly massive for all of that to be true, and if the fuel is being thrown around enough then perhaps a smaller tank is in order?
Post by: Bill Little on September 13, 2012, 11:27:03 AM
I once had a Fox.35 stunter that would cut off in the first loop of the clover.  That loop acted just like a "cut off" loop.  And the tank was not empty, but it changed with a new slightly larger tank, hotter plug and muffler pressure.  I could even pull fuel out of the new tank and everything still worked fine. ???
BIG Bear
RNMM/AMM
Post by: Brett Buck on September 13, 2012, 02:00:12 PM
   The issue is that the fuel us getting pulled down to the bottom and front of the tank as a result of the acceleration of maneuvering. It doesn't go to the equilibrium fuel surface because it's the acceleration changes too quickly but it goes in the expected direction. Tilting or tapering the tank makes it hang around the rear of the tank longer. Increasing the wedge angle makes it hang around the peak of the wedge longer.
    I have experimented with this pretty carefully. I built some tanks for the PA61 that just had dimensions that came out even, including the wedge angle. They had the same issue described here. Not quite quitting but going lean in both inside loops and then running a fair number of laps after. Reducing the fuel load to eliminate the excess laps led to it quitting. I made two more tanks with the wedge sharper by one click of "grid" on my CAD program, and then I could run much closer to the end without any anomalies. One more click of "grid" on the next tank, with a more acute angle, could run to within a few laps. My current tanks can be run with as little as 2-3 laps after the pattern and they do not change AT ALL in the overhead or 4-leaf.
    This is all actually very critical in FAI  - you don't want the engine running funny in the 4-leaf but you can't afford to run excess fuel just to mitigate it because of the possibility of running over the 7-minute time limit, particularly at low lap speeds.
    Note that in some cases you have have worse issues in the overhead than the 4-leaf since the outward acceleration is lower.
     I would also point out that the trim and overall fuel load of the airplane makes a big difference. Nose-out yaw trim makes the fuel want to run to the front of the tank more than it would otherwise. Lots of fuel means lots of CG shift, particularly on light airplanes, and that makes the yaw angle more nose-in as the flight goes on. There are a lot of variations on this theme but that's why a good tilt or a lot of wedge obviates having to consider the fuel load based on the trim.
Post by: Jim Kraft on September 13, 2012, 03:17:08 PM
Well, I learned something here today. My Magician/McCoy 40 Red Head has this same problem. If I cut it just a little close on fuel it will quit in the first or second loop of the clover. It will restart after I have leveled off, and run several laps afterwords. I will make a new tank with more wedge at the rear and see if that helps. It does not happen very often. Usually if I fill the tank and it sets for a while before I fly, It pukes a little fuel out the venture and looses just enough fuel to make it quit in the clover. Thanks for the info Brett.
Post by: Brett Buck on September 13, 2012, 04:12:09 PM
    Try a 1/8-1/4" of shim underneath the back end of the tank to tilt the back end outboard.
    BTW, the problem is in the first loop of the clover. It might quit in the second but that's only because of the empty space in the line from the first loop. Most of the time - NOT EVERY TIME - if it gets through the first loop of the clover, it will make it through the other 3. The combination of the altitude of the first loop reducing the outboard acceleration and the nose-out motion of the airplane in the loop make it much more prone to flow away from the pickup during the first loop. It does something similar in the first part of the 4th loop but you end up with the fuel flowing to the back of the tank rapidly as you complete it and more outboard acceleration, so it USUALLY - NOT EVERY TIME - keep going even with slightly less fuel.
Post by: Chris Wilson on September 13, 2012, 05:20:11 PM
I would love Kim to get back to this thread as it seemed that the chronological order of events in the original post ran, pre-ignition, muffler change, no pre-igntion, runs beautifully but NOW (as in from this point in time forward) the engine plays up in the clover.
So did the engine cut out issue exist before the muffler change or as a result of it.
Either way, good information (as always ) Brett.
Cheers.
Post by: Gerald Arana on September 13, 2012, 08:11:28 PM
Guys,
Its me Kimerski is talking about. This is on my P-40 Shark prifile ship. I think the pre ignition was actually the rubber extention I had on the RO tube muffler. Don't know. I have three head shims in to stop the preignition but I don't think that is it. I'm also using an OS A-3 which is kind of short IMO or so it seems to me. I now have my tank mounted with 1/4" of tilt and that solved the uneven run at the end of the run. I used a 12.25X3.75 APC and it flew ok, but that prop makes it nose heavy. It weighs 2-15 (47 oz.) I'm going to try a bolly 12+ X4 CF prop and see if that works OK. I also want to try a Vess 12X4.........But that belch has to go away first! HB~>
I told Kim the perimeters so I'll repeat the here; 6mm venturi (LA 25), std. OS NVA, three head shims (Yes, I know-I'll take 1-2 out) and an OS 762 muffler. That is the one that came with the FP 35 as I understand it. It has a very small outlet and gives very good gas mileage. Also cuts the noise level a BUNCH!!!! And 10-22, 50/50 fuel.
Jerry
Post by: Jim Kraft on September 13, 2012, 08:24:50 PM
Thanks Brett. I will space the rear of the tank out some and try that. I am betting that will work.
Post by: Kim Mortimore on September 13, 2012, 08:29:27 PM
Randy, tank to engine is 5/8", profile as Jerry mentioned.  Jerry, per Chris' last post, was the belch happening before the muffler change (also, was it happening before I suggested the 1/4" tank tilt?  I think you made both those changes around the same time(?)  Brett, your info about the angle of the wedge on T-21 style tanks is totally new to me, and very helpful.  Excellent advice as always.  Much appreciated!
Post by: RandySmith on September 13, 2012, 08:45:02 PM
Hi Kim
Thanks , the tank seem OK but they do need to be kept as close to the engine as possible without touching. The profiles also are very easy to shim one end of the tanks, so you should have an easy time tweeking this
Post by: Rafael Gonzalez on September 15, 2012, 06:46:22 AM
Chicken hopper tanks are made for that specific purpose. On overhead sharp turns in slow combat, if one does not use a "clunker" tank, a chicken hopper tank needs to be used. Some uniflow stunt tanks were made with an internal baffle inside, so the fuel would not "fall" from the pick up line if the centripetal force was not enough to keep the fuel at the wedge or from flowing forward.
 D>K
Post by: Gerald Arana on September 17, 2012, 03:04:32 PM
Went flying yesterday. Tried several props, plugs and even pressure. No satisfactory results.........
Today I decided to do some work on the engine. (Did I mention that it had a plastic back plate?) I took the engine off the plane and started to unscrew the BP when I notice a screw missing.  HB~> HB~> Do you think this might have been the problem? Or at least some of it?
I now have a metal (Thank you Curtis Shipp) back plate and will test fly it in Woodland Fri.
Jerry
Post by: Balsa Butcher on September 17, 2012, 06:08:21 PM
I think it was the problem and see you friday.  8)
Post by: Chris Wilson on September 17, 2012, 06:36:34 PM
The plot thickens .......... hmm lets see, previous history of pre-ignition, suspected cause muffler(?) that is now disputed by a leaking back plate.
What's a bet the extra air inducting from that now found leak has been the trigger all along!
Post by: Gerald Arana on September 24, 2012, 10:11:44 AM
Culprit found! It was indeed the back plate screw! With the exception of me hitting the ground  HB~> on Sunday, the engine ran just as it always had, great!
Oh, me hitting the ground? Well, I needed about 4" more of space. Uh.... broke my $30-40 bolly 2 blade CF prop but that was the only damage 'cept to my pride  LL~ LL~ (and a bent NV which I straightened)
Jerry
