  • June 21, 2025, 09:48:17 PM
Author Topic: OS-40 MAX-H  (Read 1531 times)
Offline Allan Perret
  • Proverbs
OS-40 MAX-H
« on: October 31, 2014, 04:49:33 PM »
Flying buddy has one, tried to get it running for him.  No compression.  Took it apart thinking ring might be stuck, but it wasn't.  Probably needs P&L and ring. Its old, history unknown, but lower end seems to be in good shape.  Are parts still available ?   Anyone still rebuilding these ?
Allan Perret
AMA 302406
Slidell, Louisiana
Re: OS-40 MAX-H
« Reply #1 on: October 31, 2014, 08:04:25 PM »
Theres TWO of them there H40 maxes , according to some tripe .
The ' R/C ' stamed ones pre 73 and same bore & stroke as the 40 S & 40 P .
The post 72 thing with the ' 40 ' on the bypass pad ( only ) is the later grunter with different Bore & Stoke .
see your P.M. 's .
Re: OS-40 MAX-H
« Reply #2 on: October 31, 2014, 11:08:51 PM »
I have many parts for them, and a couple of new ones, plus maybe a few used ones, I will have to see what is here and I can let you know what I have
