  • July 08, 2025, 11:05:10 PM
Author Topic: Engine burbles or misses after changing direction??  (Read 1845 times)
Offline frank mccune
« on: October 15, 2016, 07:01:00 AM »
       Hello All:
       What would cause an engine to slow down and misfire after changing directions? This happens whether upright or inverted.  The engine runs a perfect 4-2-4 until there is a change in direction.  It takes about 2 seconds for the engine come back to a good run.
      The set up is an O.S. .40S in a Green Box Nobler, 11X6 prop and 59'-6" lines.  Fuel is 28% oil, 50-50 and 12% nitro.  The glow plug is a Fireball med. RC.  Perhaps a change of plugs would help the problem.
     Other than this problem, this is a wonderful flying combination! The engine other than being obsolete, is a great engine!  Despite being ringed, it is very easy to start and needle.
     I just had a revelation, perhaps the tank is NOT an uniflow as I was told.  I will try it today WITHOUT  capping the overflow tube and see if the problem abates.  I will post my finding later today.
        Thanks for reading,
        Frank McCune
Re: Engine burbles or misses after changing direction??
« Reply #1 on: October 15, 2016, 10:45:00 AM »
is this the plain or ball bearing  one?  if ball bearing  you should drop the  oil down to 23 or 24%
and either  way you should drop the  nitro down  to under 10% and try that
Online Motorman
« Reply #2 on: October 15, 2016, 12:19:25 PM »
Allot of those Fireball Mediums had bad seals in them. Try a better plug.
Offline Brian Hampton
« Reply #3 on: October 15, 2016, 04:45:09 PM »
With these first version H-40's most had just a single rear ball race except for the 40P and 40R. Easy way to tell at a glance is with the prop driver. Twin BB engines have a longish spool type driver while the rest have a drive washer that extends back inside the crankcase where a bearing could be fitted so appears quite short.
« Reply #4 on: October 15, 2016, 04:55:00 PM »
       Hi All:
       This engine has one ball bearing located in the rear of the crankshaft.  It is named the .40 S which was designed to be a control line stunt engine hence the S under the .40 on the crankcase. The engine is circa 1971.
       I did not fly this engine today.  The next time that I go flying, I will fly it.
        Thanks for all of the replies,
        Frank McCune
« Reply #5 on: October 15, 2016, 04:59:45 PM »
       Hi All:
        Frank McCune
Put a new   RC HOT  plug in it, and use 24%  1/2 synth fuel   next time either  5 or 10%  ,   this time of year 5 should plenty
