Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
June 22, 2025, 01:07:46 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
What is the best way to protect the needle valve on a profile plane?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: What is the best way to protect the needle valve on a profile plane? (Read 2586 times)
frank mccune
AMA Member
Trade Count:
0
Admiral
on:
June 28, 2014, 06:04:10 PM »
Hi All:
What is the best method to protect the needle in the nva on a profile during an inverted landing?
Tia,
Frank
Logged
Steve Helmick
24 supporter
Trade Count:
0
Admiral
Re: What is the best way to protect the needle valve on a profile plane?
Reply #1 on:
June 28, 2014, 06:43:55 PM »
Best is rear NV, mounted parallel with the engine's cylinder...IMO. The Magnum/ASP remotes are quite nice, but I haven't actually run one myself. I put two on MECOA .28's, but those went to Glenn Reach (and haven't heard a word about how they ran, OBTW!).
I've run the OS .25LA with the stock RNV and didn't like it at all, but the threads are loose, NV wobbles like Elvis, so they leak badly.
Logged
In 1944 18-20 year old's stormed beaches, and parachuted behind enemy lines to almost certain death. In 2015 18-20 year old's need safe zones so people don't hurt their feelings.
Tim Wescott
25 supporter
Trade Count:
0
Admiral
Reply #2 on:
June 28, 2014, 06:48:31 PM »
The OS FP 20 remote needle valve is very nice. The only complaint I have is that the fuel can pull back from the spray bar to the needle before you get the engine started -- this makes the prime more critical if you're hand-flipping, but if you get it right the fuel gets to the spray bar before the engine cuts out.
If you're still crashing often, I'd say the advantage of not bending needle valves all the time outweighs the disadvantages.
Logged
Mark Scarborough
2015
Trade Count:
0
Admiral
Reply #3 on:
June 28, 2014, 09:03:23 PM »
bend a piece of 3/32 music wire into a U shape,, about an inch or so long,, stick it into the top of the fuse next to the needle valve so that the u is taller than the needle,, now when you flip over it will hit the U instead of the needle
Logged
Dennis Moritz
22 supporter
Trade Count:
0
Admiral
Reply #4 on:
July 01, 2014, 08:58:14 AM »
If your fingers still work ok (no carpal, no diabetic numbness or whatever) and you keep your wits about you when the engine lights up, cut the needle back to the clicker. Adjust needle by carefully spinning the disk. Saves the needle. Possibly shreds your fingers.
Logged
Robert-Jan
Trade Count:
0
Lieutenant
Reply #5 on:
July 02, 2014, 03:30:53 AM »
http://lijnbesturing.nl/index.php/informatie/fotos?view=album&album=5699869323582862289&page=1
look at picture #19 and 20.
Put an aluminum elbow
behind
the needle and mount it at the engine.
We have "test" it many times
Greetings Robert-Jan
Logged
frank mccune
AMA Member
Trade Count:
0
Admiral
Reply #6 on:
July 03, 2014, 06:15:00 AM »
Hello Robert-Jan et.al.
Thanks for the replies.
I have some aluminum angle stock that will work well for making a needle guard.
I mounted a wheel on the top of the nose just for laughs. Looks very crude but effective! Lol
Stay well,
Frank
Logged
Trade Count:
0
Admiral
AMA78415
Reply #7 on:
July 04, 2014, 02:04:47 PM »
On Fox needles or any other ones that are solid, I just cut the end off and bend them over like a Super Tigre needle. I have never broken on by doing that and they are still easy to adjust.
Logged
James C. Johnson
24 supporter
Trade Count:
0
Commander
Reply #8 on:
July 10, 2014, 08:27:02 AM »
Back in the day we used to use a piece of plywood bolted on the outside using the engine bolts.. it sticks up but works like a charm... we used to also put a single wheel sticking up... mostly for touch and go's inverted..
Logged
frank mccune
AMA Member
Trade Count:
0
Admiral
Reply #9 on:
July 11, 2014, 08:04:51 AM »
Hi All:
Thanks for the replies!
On one plane, I put a very thin, 1/8" wheel mounted via the top front engine mounting bolt that protects the needle valve well.
On another, I made a bracket from aluminum as pictured in one of the replies. It seemed to be too much labour for the task.
If I fabricate another "guard" it will be a very simple piece of plywood or aluminum attached by the engine mounting bolts on the outside of the fuselage.
Stay well my friends,
Frank
Logged
Chris Wilson
Trade Count:
0
Admiral
Reply #10 on:
August 06, 2014, 08:46:45 PM »
I have always liked the coil spring Enya type needle valve posts - hard to seriously hurt something that will simply spring back in place after being knocked
Logged
MAAA AUS 73427
Nothing in life is so exhilarating as to be shot at without result. It's not enough that we do our best; sometimes we have to do what's required
Garf
Trade Count:
0
Admiral
Reply #11 on:
August 23, 2014, 09:35:10 PM »
Try planting the plane hard inverted. Those spring NV's will break. I have done it.
Logged
"SAVE ALL THE PIECES"-Phil Brown
http://hangarflying.proboards.com/index.cgi?board=wire
Chris Wilson
Trade Count:
0
Admiral
Reply #12 on:
August 26, 2014, 03:39:19 AM »
Quote from: Garf on August 23, 2014, 09:35:10 PM
Sounds like a face plant of the quality that you are describing would break off any protrusion Garf.
My point is the more flexible it is the less that it will need protection in the first place - kinda solves the problem before it starts.
Angling the needle valve back will also give some modicum of protection.
Logged
MAAA AUS 73427
Motorman
Trade Count:
0
Admiral
Reply #13 on:
August 29, 2014, 06:27:39 PM »
Just before you land give it full down then full up and bonk it square on the nose.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
