  • June 19, 2025, 09:59:04 AM
Author Topic: Omega control line fuel  (Read 7965 times)
Offline Brad LaPointe
« on: March 14, 2017, 09:59:10 AM »
Omega (Morgan) offers a 10% nitro 11/11 mix fuel for control line . I never have used this and wonder what your experience is with this product.
Most of the time Brodak 40's and LA 46's would be run . The local hobby shop carries Omega and would probably order some if I want a case or two .
Brad
Re: Omega control line fuel
« Reply #1 on: March 14, 2017, 07:47:32 PM »
blank
« Last Edit: March 06, 2022, 09:06:21 AM by Motorman »
Offline ray copeland
« Reply #2 on: March 14, 2017, 08:37:23 PM »
Brad, I burn Omega 25% in my 1/2a's for years and it works great. Not a 11/11 blend but it is good fuel. I would give it a try, if it was local I would try it.
Offline Jim Oliver
« Reply #3 on: March 14, 2017, 08:38:42 PM »
Several years ago the Central Alabama Stunt Squadron worked with Morgan to develop a fuel that would work for CLPA use.
The fuel that you mentioned is the result of that project and is mixed to give the correct proportions of oil vs. methanol vs. nitro.
Morgan Fuels donated several cases of quart containers of this fuel to our club, to be given to those who entered the CL contests that we were holding at Clanton, AL during this time.
I was personally involved in this project and spoke to many of those who received free fuel at our events (and to many who purchased this fuel in larger containers), asking them to rate the Morgan fuel performance relative to whatever they had been using.  That has been several years ago but I can't remember a single negative reply about the Morgan fuel.
Give it a shot, I think you will be pleased.
Jim
Jim Oliver
AMA 18475
Offline Allan Perret
  • Proverbs
« Reply #4 on: March 15, 2017, 07:50:51 AM »
Jim
I though Morgan had discontinued the cl blend ?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #5 on: March 15, 2017, 08:21:20 AM »
Morgan still showed it as of yesterday on its website. I understand that it doesn't mean that they still offer it.
Thanks for the testimonies of the fuel . I will try a case if it is available.
Brad
Offline badbill
« Reply #6 on: March 15, 2017, 11:04:53 AM »
Tower Hobbies sells it and it is good stuff. Kind of expensive at $8 a quart though. I have switched to regular Omega 15% RC Fuel in gallons, I get it through the club I'm in for $15 a gallon. I pour it into quart bottles and add 2 oz of castor a quart, and can't tell the difference between that and the CL fuel. Works great.
Bill Davenport
AMA 28141
Offline Jim Oliver
« Reply #7 on: March 16, 2017, 10:13:58 AM »
I just now spoke with the nice lady at Morgan Fuels.
The CL blend is available and may be ordered by you local hobby shop.  It is available in quart or gallon containers.
Also, it may be ordered directly from Morgan Fuels or it may be picked up at the plant, with 24 hour notice.
Contact is: 334-347-3525
Jim
Disclaimer:  I have no financial connection with Morgan Fuels:)
Jim Oliver
AMA 18475
  • Proverbs
« Reply #8 on: March 16, 2017, 10:22:32 AM »
Jim
Problem was that LHS gets fuel from a hobby distributor, not direct from Morgan. I remember now that is was my LHS that told me they couldn't get it anymore because their distributor stopped carrying it based on low sales volume.  That caused me to find another option but do remember that it worked fine in several stunt motors while I was using it.  Probably went  thru 3-4 gallons.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Russell
  • ACE
« Reply #9 on: March 17, 2017, 02:00:04 AM »
Brad
I started using it last year when I saw it at Tower Hobbies with free shipping and yes it works very well. After a trail quart bought 4 gallons.
Offline Jim Oliver
« Reply #10 on: March 17, 2017, 09:10:42 AM »
Just for clarification,
I just now spoke with Morgan Fuel and they confirmed to me that they do sell direct to local hobby shops, to distributors and direct to consumers.
Jim
Jim Oliver
AMA 18475
Offline Peter Nevai
    • C3EL
« Reply #11 on: July 06, 2017, 10:13:00 PM »
Is this the same Cool Power pink stuff? I burned up a number of engines with this stuff and had runaway problems galore.
Eric Viglione
« Reply #12 on: July 07, 2017, 06:34:51 AM »
Some one can correct me here if wrong, but cool.power is usually but not always green, and is all synthetic fuel. Not only is it synth, but low volume of synth. Omega is a synth/ castor oil blend..
Omega ran fine in modern engines for me with an ounce or two of Aero One added... needs some more doctoring to use in certain old plain bearing engines known to run away. I certainly could live with it if it was all I could get.
If you are prone to tank problems or dirt in your fuel system, I think any fuel could potentially let you down after several sagging lean overheated run incidents. On the other hand, I think the reverse is almost equally true, "almost" any reasonable fuel formula made for CL use that is ran in  nice steady stunt runs scenario will do fine. Sure, some will give better or worse run characteristics but most will get the basic job done. The harsher the environment the more critial it gets.
Eric
« Reply #13 on: July 07, 2017, 07:23:53 AM »
I relented my effort to have the local hobby shop order some of this fuel . The owner didn't seem too eager after the importer didn't stock it.
Luckily we made it to the Toledo show this spring and we stocked up on Richs Brew . This is the best way for us as driving to Toledo is 2.5 hours away. Getting a dozen cases of fuel thru customs can be "interesting " . Much cheaper than LHS prices.
Brad LaPointe
MAAC 5418
« Reply #14 on: July 07, 2017, 10:15:14 AM »
Eric
Hi Eric
Yes  Cool Power  is green and 14.7 percent oil  , all Synth, Omega  used to be pink with 14.7%  total oil , with 2% castor , From what I understand the have boosted the castor content and total oil content in the  CL version of Omega, I have not done a boil down test on it yet, but they normally  mix fuel by weight , and not volume, maybe some of the Alabama guys knows  the  oil content
« Reply #15 on: July 07, 2017, 10:18:37 AM »
BLEND       NITRO                     LUBE   LUBE PKG
Omega Control Line 10%      22%   50% Castor & 50% Synthetic Blend
per  the Morgan  Web site  blend is the above:  if made by weight the  oil content is going to be down near  17 to 18 % oil
Should be good for modern ball bearing engines, OS LA  types  with larger bushings and bushed rods,   Keep it  OUT  of Fox 35s and OS 35S  type older engines.  Or add 9 to 10 ounces of castor  to a gallon
and it is if made by weight , figure  its really 7 to 8% nitro / 17 to 18%  oil
The good part is they are very Large company, and they made a huge amount of the markets  fuel!  so they should alway be around, and the fuel should be consistant
Offline badbill
« Reply #16 on: July 07, 2017, 10:45:51 AM »
On the bottle it says it is mixed by volume, not weight.
Bill Davenport
AMA 28141
« Reply #17 on: July 07, 2017, 12:17:50 PM »
ALL  of the other  Morgan fuels  are mixed by  weight , so  if  that one fuel   is  mixed  by volume, and only that one fuel, then that is  great for us ,  that way we get a true  22% oil  , but the only way to tell for sure is to do a boil down test on it.
Offline badbill
« Reply #18 on: July 07, 2017, 12:53:01 PM »
Randy, I'm pretty sure that after they made it for a control line club and then donated a bunch of it to that club, they wouldn't lie about it on the bottle. But you go ahead and boil it down LOL
Bill Davenport
AMA 28141
« Reply #19 on: July 07, 2017, 01:36:25 PM »
Where did I say they lied about the  Control Line fuel ??    why do you  try to  insinuate  things I never said ?
by the way I have boiled down many batches of their fuel, and   NONE of  it was as claimed  ALL  the 18%  Cool Power  was  14.7 percent oil
Offline badbill
« Reply #20 on: July 07, 2017, 02:09:43 PM »
Take a deep breath and chill Randy, I never said that... You're the expert not me.
Bill Davenport
AMA 28141
« Reply #21 on: July 07, 2017, 04:01:11 PM »
I am just fine, no problems here, I do want people to know what they are putting in their engines, as I have seen Fox 35s, and OS 35s  wiped out from 1 run on Cool Power and Omega.
Now if they are making Omega  with 22% oil rather than the 14.7 is was, Then I am happy , and will encourage people  to try it, and if it has changed  to Full 22% oil and full 10 % nitro by volume  then we owe them  gratitude and should support Morgan fuels.
Netherless I stick by  the way to tell is to test it, no sense in killing engines  to test fuel
So bottom line  run what you want, just make sure you know what it is
Offline Peter Nevai
    • C3EL
« Reply #22 on: July 14, 2017, 06:30:06 PM »
SIG Champion 10 and 15 seemed to work well for me, but I wonder now if when I get the Pathfinder finally finished and the VF46 installed if I should still run the SIG Champion fuel in it. It is 50% castor.
« Reply #23 on: July 14, 2017, 07:18:09 PM »
Peter
Sig Champion  will work fine, but  will kill plugs faster, and  varnish more, I buy SIG  Champ and  SIG  4 stroke all synthetic fuel and mix it half and half, that way it  1/4 castor  , and  does not grow taters    like heavy castor does, and keeps  the  engine  cleaner
Offline Peter Nevai
    • C3EL
« Reply #24 on: July 15, 2017, 07:36:05 PM »
Peter
Thanks Randy for the suggestion, I will do just that 50/50 SIG champ 10 and SIG 4 stroke. Easy to measure out and mix :)
« Reply #25 on: July 15, 2017, 08:37:37 PM »
   Use Powermaster 10% "Air" - it doesn't kill plugs at all.
