Hi, Steve,
On my PA engines, I try to run them 1.5-2 hours on the bench, short runs, varying speeds. Both seemed to become "friendlier" at about the 1 hour mark. Outstanding engines! The PA 61 side exhaust is using about 6 ounces for a pattern, with comfortable time after. Noel's PA 65 side exhaust, as I recall, is using a little more...maybe 6.5 ounces or so. With Randy's guidance, we are running these a little below the "pipe style" run, with very good success! Great 4/2/4, super power. Using the newer Pro Zinger 13/4 and 13/5 props is working well.
