  • June 22, 2025, 01:12:40 PM
Author Topic: 1/2 A fuel - What percentage do you recommend?  (Read 760 times)
Offline Mark Misegadis
« on: July 21, 2009, 11:11:48 AM »
Currently running Cox motors with an AP .061 tossed in for fun. We are running either 18 or 20% Caster with 35% nitro. Sig or Wildcat are the two brands.
The 20% caster seems to leave things a little messier than the 18%. I have read numerous posts with widely varying opinions on the percentage of nitro to use.
We are at 6000 feet so therefore things work a little different here and perhaps this is why for regular sport flying I see lower percentage answers from everyone else in their similar posts.
Cox fuel worked fine back in the day. Does anyone have a figure on what the percentages were for it.
Thanks in advance for your advice.
Mark
Re: 1/2 A fuel - What percentage do you recommend?
« Reply #1 on: July 21, 2009, 08:32:43 PM »
Hi we used
Missle Mist  which was 25%  I would suggest using at least that and maybe stick with the 35% at your 6000 feet
« Reply #2 on: July 23, 2009, 09:28:11 AM »
Thanks Randy!
Offline Larry Renger
« Reply #3 on: July 23, 2009, 11:24:00 PM »
I like 15% for the Cox reedies and Medallion, 25-30% for the Tee Dees.  For Norvel and AP Wasp, 10% is just fine.  For all, 18% minimum oil, half of it castor.  More oil assures less likelyhood of overheating, but costs fuel consumption (no apparant loss of power).
