  • June 19, 2025, 03:02:07 PM
Author Topic: McCoy 40 and OS 49  (Read 1575 times)
Offline Neville Legg
McCoy 40 and OS 49
« on: March 21, 2010, 03:45:57 PM »
I have just won a McCoy 40 Lightening Case version, from Ebay (very good deal!) it looks new, was this a better version than the earlier plain case version, or does the piston need hardening, to use a silencer?
I also won a boxed OS49 from '62, offset plug, once again this was a very, very good deal, its in good condition apart from a couple of the small cylinder head fins missing at the front (anyone got a spare head? ;D) does anyone have any experience of this rare-ish motor?
Cheers          Neville
(not) Descartes
Re: McCoy 40 and OS 49
« Reply #1 on: March 22, 2010, 07:05:38 PM »
 I have two of the older Red Head McCoy 40's, but I have never run mufflers on them. They are very good stunt engines though. They really like an APC 12-6 prop cut to 11". Some heat treat the pistons with a torch which also grows the piston a little. That is supposed to make them more resistant to the extra heat from the muffler. I believe Tom Lay does this to them. Sorry, I do not know if the "bolt" engines have better pistons in them or not.
Offline Scott B. Riese
  • Just a student of stunt
« Reply #2 on: March 23, 2010, 12:22:45 AM »
SNIP>>I have just won a McCoy 40 Lightening Case version, from Ebay (very good deal!) it looks new, was this a better version than the earlier plain case version, or does the piston need hardening, to use a silencer?
I use a McCoy 40 Lightening Bolt in my 35 Stuntwagon. I also use an muffler that I make for McCoy's. I have excellent runs. Lots of fun!
Scott Riese
Portland, Oregon
AMA 528301
« Reply #3 on: March 23, 2010, 01:26:27 AM »
Thanks chaps, I think I'll use the McCoy as it is. Scott, do you make McCoy silencers on a commercial basis? I take it nobody has heard of the OS 49 ????
Cheers    Neville
(not) Descartes
« Reply #4 on: March 23, 2010, 10:36:40 PM »
Cheers    Neville
HI Neville,
The 40 you got from me was heat treated by Tom Lay for muffler usage. ;D  have you run it yet?
Never have seen the OS 49..........  :o  :-[  :(
« Reply #5 on: March 24, 2010, 01:49:22 AM »
Hello Bill hope you are well, I couldn't help buying this McCoy as it looked new and was very cheap! I shall use the one you sent me, just deciding what to put it in! I have an old spinnerflo silencer that fits it. The OS 49 was fairly rare, its from '62, I think it was dropped in favour of the 50! Have you run the Merco yet?
Cheers        Neville
« Last Edit: March 25, 2010, 01:17:16 AM by Neville Legg »
(not) Descartes
Offline Andrew Tinsley
« Reply #6 on: March 24, 2010, 12:17:19 PM »
Hallo Neville,
  Never seen or heard of the OS 49, but I do run the McCoy lightening bolt 40. I have two and they are very much better than the McCoy 35 (even a good one!). I too was bothered by silencer use. In fact I chickened out! Eventually I made a new piston for one and used a modified Merco silencer! It worked thank goodness!
Andrew.
BMFA Number 64862
Offline Bill Morell
« Reply #7 on: March 26, 2010, 08:05:46 AM »
The OS 49 came in a series of 3 engines. 1 49, 1 50 and a 58. All look pretty much the same. None of them were a real power house but give a decent stunt run when a proper sized venturi is used. All of them have a drip of fuel out the front bearing. Frank Bowman used to make a brass? or bronze? bushing to replace the front ball bearing that cured the drip. (That sounds almost wrong!) I have a 49 on a Viking and it pulls it just fine.
Bill Morell
Vietnam 72-73
« Reply #8 on: March 26, 2010, 11:44:43 AM »
Hello Bill, what size venturi are you using? the 49 I have has an R/C carb on it at the moment. Any idea were you can get parts for this engine?
Cheers      Neville
« Last Edit: March 26, 2010, 01:06:31 PM by Neville Legg »
(not) Descartes
Offline Bill Morell
« Reply #9 on: March 26, 2010, 08:20:36 PM »
Neville, I have a venturi from a ENYA 40 6002 in mine. As to parts, good luck. EBAY is about as good a source as any.
Bill Morell
Vietnam 72-73
« Reply #10 on: March 28, 2010, 01:22:01 PM »
Cheers    Neville
Yes I make Mufflers and Venturis.
The OS-49...I just re-bushed one. I also Hemi a head for one. I test ran the engine with good results and sent it back to my customer. It's now in a Wildman.
Scott Riese
Portland, Oregon
AMA 528301
« Reply #11 on: March 29, 2010, 03:29:06 PM »
Scott, how much are the McCoy silencers? I live in England. Can you post a picture on here? What bushings did you replace on the OS?
Cheers    Neville
(not) Descartes
« Reply #12 on: April 04, 2010, 12:12:25 PM »
Cheers        Neville
Hi Neville,
I haven't had a chance to run the Merco yet.  :'(  It just looks so nice!
I got plans for Ken Taylor's 1956 Centuar which has an upright, exposed engine.  Perfect for the Merco 35 RH!
Best wishes!
Big Bear
