  • June 22, 2025, 05:57:17 AM
Author Topic: Fox 40 - Fuel, Prop?  (Read 769 times)
Offline Frank Sheridan
« on: June 07, 2009, 11:38:09 AM »
Anyone familiar with this engine? I'm going to mount it on a scratchbuilt profile plane. It has a single ring. It weighs a ton (11 oz.). Will it be happy on a 5% nitro, 30/70 castor/synthetic (17% total) blend? Any prop suggestions?
Re: Fox 40 - Fuel, Prop?
« Reply #1 on: June 07, 2009, 08:16:55 PM »
Hi Frank
It is hard to tell from the one side pic, but it looks like a FOX 50
I would run at least 20% oil in it for CL, maybe even 22%
« Reply #2 on: June 07, 2009, 11:02:59 PM »
Actually, I believe it is an early Fox45. I had one of the 50BBs back in my R/C days, and it said so on the side of the case. I hope it runs as well as the 50 did.
Offline dennis lipsett
« Reply #3 on: June 08, 2009, 06:51:08 AM »
That's a wart /bump case from the 70's. I flew a few of them ,RC only, and can say that they definitely like nitro, 15% at the least. I  Used 11 inch props on them. They are also not slow running and I don't know if they would be acceptable for U/C other then sport flying. Quality of those engines was all over the place, fits were in some cases enough to give you 'fits'. That said someone will probably jump in to give more info, or have a different perspective on them.
dennis
