I am running a crap trap fuel filter. and the stock muffler. Rubber ducky? Do you mean the dubro rubber exhaust deflector? If so no. I am flying the beginner pattern so I do not need the full tank. That is why I was only running 2 1/2 oz. I do not think that I am over lean but I do not have a reliable tach. Could I go richer? yes But I have not had the chance to try it yet to see if it runs away. Since I am running more oil it may stay consistant. I would like to get it in a rich two just off of a four. If it does I may need to go to a larger venture to get the rpm back up.
Ah, knowing it's the Beginner's Pattern makes the fuel load sound a lot more reasonable. But I'd go with the stock venturi and use a layer or two of pantyhose mesh over it to effectively reduce the venturi size...and keep "the stuff" out. That's another reason to use muffler pressure...keeps the micro bugs and micro seeds out of the fuel tank and thus, filter. Plus, it prevents rich/lean when going up/downwind. Yes, there are other fixes for this, but muffler pressure isn't a bad thing.
Try some different props. The 11.5 x 4 APC works well for me, and locally, Tim and Tom use the 11 x 4.5 Thunder Tiger Cyclone. I still say to change the tank to uniflow, add muffler pressure, and launch richer. If it sags overhead, it's clearly too lean. Try doing 2 OH8's instead of the WO and see if it goes lean. I'd suggest getting a tachometer (Hanger 9 Mini-Tach, $28) and use it to set the rpm before every flight...and I mean, EVERY flight.
Have you read the "sticky" topics at the top of this engine forum about OS .46LA setups? Randy Smith's articles? Some good stuff in that lot.
