  • June 23, 2025, 06:25:48 PM
Author Topic: Reworking R/C for stunt  (Read 2659 times)
Offline Craig Campbell
« on: June 20, 2013, 05:56:32 AM »
I am after any info I can get on reworking a engine from R/C to stunt I have a HP 40 Silver Star and would like to make it run in a stunt model. I have been told to take a little off the liner and open the squish band up to drop the compression a little.
Or if there is somewhere I can send it to be reworked that would also be good.
ChrisSarnowski
Re: Reworking R/C for stunt
« Reply #1 on: June 20, 2013, 06:02:39 AM »
Lots of people are happy with Byron Barker's work. His contact info is in the link below.
-Chris
http://stunthanger.com/smf/index.php?topic=11410.0
Offline Roger Vizioli
  • CLiner
« Reply #2 on: June 20, 2013, 08:58:39 AM »
Randy Smith, Aero Products, mod'd them years ago.
I have one that he modified, I bought it off a table at the KOI many years ago and it runs great, has for years.
Roger Vizioli
Roger Vizioli
AMA L-2408
Florida/Space Coast
« Reply #3 on: June 20, 2013, 04:55:28 PM »
You might talk to Jim Lee at Lee' Machine Shop. He just did a GMS .32 for me I'll use in classic.
« Reply #4 on: June 20, 2013, 06:46:28 PM »
It really doesn't take much to make the Silver Star run for stunt providing it's in good condition and has descent compression.
Replace the Carburetor with .280-.285 venturi and a Super Tiger needle valve assembly obtained from just about any of the aforementioned folks.  I personally would recommend Randy Smith at Aero Products or Jim Lee.
As for the compression a .007 to .010 shim would be all that is needed in any case.  I would probably just try it with the stock head gasket first.
Use an APC 11-4 or or 11.5-4 prop at about 9600 RPM (ground launch) on 65 ft lines.  Should work fine in a 575 to 620 Sq in airplane.
I used one in a Wooley Cobra with that setup and it was great.  Shortened the nose of the Cobra by 1 inch to accomodate the extra engine weight.
Offline Andrew Saunders
  • 2013 Nats
« Reply #5 on: June 20, 2013, 07:13:51 PM »
I have two engines that were reworked by  Byron Barker and they run great.
« Reply #6 on: June 21, 2013, 06:30:18 AM »
Thank you all for the info Much appreciated  H^^
Offline Ward Van Duzer
« Reply #7 on: June 21, 2013, 06:45:52 AM »
Randy had custom made AAC liners made for these a while back. See if he has any left...
W.   8)
Dwayne
« Reply #8 on: June 21, 2013, 06:46:47 AM »
Agreed, before you go spending money try a head gasket first.
Good luck  ;D
« Reply #9 on: June 21, 2013, 07:50:50 AM »
    Why do you think it won't work as it is?  This engine should run just fine if you put a regular venturi in it.
« Reply #10 on: June 23, 2013, 02:47:45 PM »
Hi Brett,
I read all the posts and no one asked Craig if he meant a 4-2 run for "Stunt".  If that is his question I would suggest that he simply run it in a wet 2 with a 4" pitch prop and take advantage of the power it can produce in "stock" trim.
BIG Bear
RNMM/AMM
« Reply #11 on: June 23, 2013, 03:47:37 PM »
   The Silver Star should do a nice break with no mods if you should want to for some reason. In either case there is no reason to immediately go do rework without trying it first.
« Reply #12 on: June 23, 2013, 04:42:18 PM »
Hi Brett,
I have 3 Silver Star .40s and two Gold Cup .40s.  One of the GC;s is NIB and the other is well broken in.  I just put new rings in all of them (the NIB GC was shipped from the factory with no ring! LOL!!)
I have never tried to run any of them with a 4-2 break, didn't even think they would do that. ???  Just 11"-11 1/2" X 4 props and a wet 2 run.  I remember Robby Hunt using a HP .40 with a pipe in his Europa.
Online RandySmith
« Reply #13 on: June 23, 2013, 08:03:52 PM »
Many Silver Star HPs  will  not work stock, many of the came with a black anodized head that has  NO fins on it, that will not work for a stunt engine, it has to be milled or replaced with another head.
There are several other things that can kill off that engine as a stunt motor..if you do not know what your looking at
« Reply #14 on: June 27, 2013, 04:26:05 PM »
I have bench run the engine with a home made Venturi it has a 7mm hole and a OS needle from a FSR. No Exaust as yet and it runs well rich flat on the bench with a 11 X 4 prop when you put the nose in the air it turns up the revs to warp speed and will not return to a nice wet 4 stroke for about 25 seconds. any thoughts
Offline Chris Wilson
« Reply #15 on: June 28, 2013, 12:45:40 AM »
Run it with a muffler?
MAAA AUS 73427
« Reply #16 on: July 01, 2013, 12:18:12 PM »
Send it to Randy!
W.   :!
