  • July 12, 2025, 09:54:52 PM
Author Topic: Diesel Conversion  (Read 1655 times)
Offline rob biddle
Diesel Conversion
« on: October 02, 2006, 08:26:10 PM »
  Hi all, I know that most will want know why would I bother, but I'm seriously considering converting an old FP .40 to diesel operation with a "Davis diesel" head.
  I love to try out new things for the sake of doing it, whether it be good or bad it just seems to be food for my withering brain **)
  The reasoning is that a diesel .40 will swing a 12x6 prop up to around 9000rpm and I figure that it should pull over 650 sq".
  I have quizzed a couple of diesel fanatics on this and they haven't had any experience with the Davis conversion and couldn't offer much in the way of advice other than to run a very small venturi and apparently abc diesels aren't particularly successful. (not stating why?)
 They both stated that the PAW .40 is very strong and will happily pull a .60 size model. Unfortunately the PAW is listed at 120 quid which equates to $301 Aud and is therefore beyond me for the present time.
  I would probably be looking at a 4 stroke if spending this much.
 The Davis conversion works out to be around $70 Aud which is more in my league.
On the Davis website the reviews look good but I don't know of anyone who has used this conversion first hand.
  Has anyone on the forum used large diesels with success? I would love to hear the pro's and cons.
  Thanks in advance, Rob.
Robert Biddle
Offline Jim Thomerson
Re: Diesel Conversion
« Reply #1 on: October 02, 2006, 09:58:10 PM »
The RJL 40 head is much cheaper than the Davis head.  I ran one a good bit on a Tower 40 and liked the results.  However, I did have a couple of problems.  First, the contrapiston came apart.  It has groove for an O-ring and the groove was close enough to the face of the contrapiston that the whole lower rim of the ring came off while the engine was running.  Not good.  Secondly, I went through four crankshafts.  The shaft has a grinding relief groove around the shaft at the base of the crank web.  Broke right across there.  I was running a 2 oz heavy hub and I think that was a contributing factor.
If I build something which is not tail heavy I may try it again.  Right now I have the head ( new contrapiston we made) on a magnum Pro 40 which has more substantial crank.  Have only run it a couple of times on the bench.
I'm running the same venturi on the Tower 40 diesel or glow, muffler pressure.  Have flown the Tower 40 several hundred flights glow with no problem, heavy hub and all.
Online Larry Wong
« Reply #2 on: October 02, 2006, 10:00:22 PM »
Rob I have tryed a Davis diesel conversion on a O S 46 on and R/C plane,
I found that it works like a 4 stroke and has a lot of torque power, does not like to run like a 2 stroke  ( high  R P M )  run it rich and a smaller venturie with a throttle about 3/4 's throttle and it will turn a bigger prop. I had a tail pipe that came out the end of the plane, it seams to like back pressure also.
I hope this will help you.  Good luck
Larry
Offline rob biddle
« Reply #3 on: October 03, 2006, 12:38:31 AM »
     Thanks gents, I think that this may be worth having ago at if nothing else.  ;D
  It may be a little while off yet as my lovely wife has laid down the law and won't let me buy any more stunt goodies until I build the kits (x3) that I have accumulated over the last few months. n1
  I guess she wouldn't know if I started on another scratch build as she was banned from my shed last time she complained about the 3 unfinished models and 2 half finished car projects.  **)
  I plan on building a 650+ sq" model with a "sidewinder" engine to allow better access to the compression vernier. It would have interchangeable "clamp" style mounts and tank access to facilitate an engine swap should the diesel conversion turn out to be a flop. :-[
  Thanks again, Rob.
Robert Biddle
Offline Ralph Wenzel (d)
« Reply #4 on: October 03, 2006, 05:15:49 AM »
Did you get my PM?
Ralph Wenzel
AMA 495785 League City, TX
Offline rob biddle
« Reply #5 on: October 03, 2006, 06:02:18 AM »
  Thanks Ralph, I just pm'd you back.
 Cheers, Rob.
Robert Biddle
Offline Scott Jenkins
« Reply #6 on: October 03, 2006, 07:06:50 AM »
Rob,
It does not matter whose head you run either will work, the key here is a good piston to liner fit much better than a glow and a beefy conrod. The venturi will probably end up about 1/3 of the size of a glow venturi better ecomony there. Banning the missus from the shed does nothing if she decides to do away with the shed and its contents  :o Keep the missus happy, or marry your stunt plane.
Scott
Scott Jenkins
AMA 43122
FAI F2C VOLUME 2 SECTION 4, 4.3.7
m) During the refuelling and the restart of the motor, and until the time when he releases the model aircraft, the mechanic must keep the model aircraft in contact with the ground by at least one point and with the centre line outside the flight circle. During that time the pilot must be crouching or sitting inside the centre circle. He keeps one hand on the ground and his handle and his lines as close to the ground as defined by the F2C panel of judges until the model aircraft starts again.
Offline rob biddle
« Reply #7 on: October 06, 2006, 12:09:03 AM »
   Hi Scott, all will be sweet as long as she does'nt look over my shoulder
whilst I type this  **)
 Cheers, Rob.
Robert Biddle
