  • June 08, 2024, 06:10:28 AM
Author Topic: Designing and building my own .049  (Read 4113 times)
Offline Dane Martin
  • heli pilot BHOR
« on: May 25, 2020, 08:12:05 PM »
So I believe I have the majority of the particulars figured out on building my own 1/2a engine. Yes, I already know it's entirely more work than it's worth. But this is the part of the hobby I enjoy.
 So I have some questions for some of the more experienced machinists and tool and die makers. On a crank such as the Cox TeeDee, or reed valve cranks for this, the prop drive is a simple as pressing a special broach. But how do you get that type of spline on the tiny crank? Is it pressed through a die? For 1/2a, would I be better suited to simply make it tapered and taper the prop drive?
Offline Dane Martin
  • heli pilot BHOR
Re: Designing and building my own .049
« Reply #1 on: May 25, 2020, 09:00:32 PM »
Real basic rough draft but almost to scale. Here's most of the case. I think I want the backplate to bolt in like a wasp. It's kinda based on my favorite aspects of the wasp, VA, and CS engines. I love the CS case and liner, but it's kinda bulky. The VA is an unbelievable size case, but split. So it'll be in between that somehow. It will be a single exhaust port in an effort to keep the plane clean...
Offline Dane Martin
  • heli pilot BHOR
« Reply #2 on: May 25, 2020, 09:55:45 PM »
Straight shaft with tapered collet is what I did. Do you make aluminum castings or will this be a billet case?
Billet case, at least on the first one. Let's see how it goes first. Might end up being a lot of hand work. But there's a few CNC companies here like Dolphin Machine who do aircraft stuff, if I get real hard up.  They're really cool. When I made a small production run of yo-yo's, they did the halves.
Offline pat king
    • PDK LLC
« Reply #3 on: May 25, 2020, 10:12:04 PM »
Dane,
The "spline" on the little cranks (Cox) are nothing more than a fine straight knurl. The hole in the prop driver is very slightly larger than the pitch diameter of the knurl. The metal needs enough room to flow without trying to compress the metal of the prop driver when it is pressed on the crank. The crank should be machined from something pre-heat treated so it is tough but there is no heat treat distortion. I don't know if I have any Stressproof or ETD 150 the right size. If nothing else it can be turned from a 1/2" socket head cap screw. The socket heads are about 38 Rc, not hard to machine with carbide tools.
Pat
Pat King
Monee, IL
AMA 168941
« Reply #4 on: May 26, 2020, 12:58:52 AM »
dane,
You probably do not need more inspiration since you seem really serious to do your own 1/2 engine.  You might already be familiar with the work that Wayne Trivin did several years ago.  Unfortunately, this master machinist/craftsman and really a good person left us several years ago far too soon.  His work can still be seen at
http://www.nclra.org/TechTopics/WayneTrivin/MyHalfAEngines.html
There is more on how Wayne built his 1/2A engines at
http://www.nclra.org/TechTopics/WayneTrivin/HalfAEngine.html
I have one of his engines, the one like the one in the picture that has the venturi on the bottom of the crankshaft which does not show very well in the photo.  Needless to say, it is in a prominent location in my display case.
The NCLRA racing people are maintaining Wayne's site at   http://www.nclra.org/TechTopics/WayneTrivin/Actualindex.html  .  Maybe Bob Whitney can add more to this.
Good luck with your endeavor.  Hope you keep us updated on your progress.
Offline Oldenginerod
« Reply #5 on: May 26, 2020, 03:08:51 AM »
If you're not familiar with it, this site is well worth spending a few hours browsing through.
http://www.modelenginenews.org/index.html
Sadly, due to Ron Chernish's passing, the website is now only an archive, but all the info is still there. Adrian Duncan would be well worth talking to regarding your plans.
Rod.
Offline Dane Martin
  • heli pilot BHOR
« Reply #6 on: May 26, 2020, 07:08:42 AM »
Will this have an iron piston or did you plan on chrome plating, do you have a source for high silicon aluminum?
How do you plan to hold the wrist pin in?
 I'm thinking of a leaded steal for the cylinder liner. From reading up on Cox, that's what they used with the addition of the black oxide finish. I won't need that step.
 I don't know if I'd be able to chrome and then hone for quite some time. That's a lot more stuff I don't have.
Looking at some of these 1/2a cranks I got laying around, there seems to be a lot of CNC ground ends. I'm thinking like we talked about, just have enough weight material to press the pin and hope for the best. But I'm reading through the material listed above. I may end up finding a better way
Offline Dane Martin
  • heli pilot BHOR
« Reply #7 on: May 26, 2020, 07:12:37 AM »
dane,
There are so many helpful ideas in the link you've supplied. I remember seeing those a while back, but now it means a lot more! His engine is FAR more advanced than what I have in mind to start with, but a lot of his processes are very helpful.
 Thank you very much Keith. Hopefully I'll see you again at a contest soon, and I'll bring whatever I come up with, with me!
Offline Dane Martin
  • heli pilot BHOR
« Reply #8 on: May 26, 2020, 07:15:34 AM »
Rod.
Rod,
Thank you for the resources. I'll read through and see if I can grab a few ideas! I'll also try and reach out to Adrian
Offline Fredvon4
  • Central Texas
« Reply #9 on: May 26, 2020, 08:11:50 AM »
Brother Dane
On CEF we have a 3D printer wizard...here is one of his way cool projects
https://www.coxengineforum.com/t14093-ball-bearings-you-say-3d-printed-bb-crankcase
Fred von Gortler IV
Offline Dane Martin
  • heli pilot BHOR
« Reply #10 on: May 26, 2020, 06:29:07 PM »
After work, I figured I'd try to make the crank for this CS .061 as practice. I wasn't successful but I learned a few things. I was cutting a grade 12.9 bolt, hrc 39-44. With the carbide tools I have, it was peeling material off like butter!
 The reason it didn't work, was my bolt head selection. It left no material where the crank pin needed to be. I'll get some more bolts and try again. I think I figured enough out today to get it done!
« Reply #11 on: May 26, 2020, 06:54:21 PM »
I actually built all of the moving pieces for a Cox TD 09, plus the cylinder and head.  It was crap.  It wore out about 5000 revolutions after it was nicely broken in.  But it did that wearing out under it's own power!
I learned a lot -- starting with the fact that just scrubbing the parts with Dawn and a toothbrush won't get all the lapping compound out of steel.  I think I also learned not to use Mystery Metal in critical wear areas like pistons and cylinders.
It even got written up (without the bit about wearing out half a second after breaking in -- I sent in the pictures after the first run in-hand): http://modelenginenews.org/ed.2012.04.html
Based on all that -- I'd suggest finding some plans for an engine (there's a few "beginners engines" on modelenginenews.org) and just building to plan.  Or grab a clapped-out engine and make some new bits (unless you've done that).  Once you get that working, even if it's not strong enough to get the skin off of hot milk, then go and build an engine.
A bit of advice that I see over and over in Model Engine News is to start with an engine from about .15 to .35 displacement -- it's felt that's a good compromise between fiddly bits that are too small for the beginner to machine effectively, and materials cost.
These may be nice, too.  You need to search out the download link: https://rclibrary.co.uk/title_details.asp?ID=2122, https://rclibrary.co.uk/title_details.asp?ID=2139
« Reply #12 on: May 26, 2020, 06:55:46 PM »
This forum will be helpful, although they'll start by telling you that the last engine a beginner wants to build is a two-stroke: https://www.homemodelenginemachinist.com/.  They may be right -- but I don't want to build anything else!
Offline Dane Martin
  • heli pilot BHOR
« Reply #13 on: May 26, 2020, 07:00:05 PM »
Very cool, I'll check it out.
The reason I've decided to build my own is that I've built almost any engine part at some point or another with varying degrees of success. I've just never built everything for one engine at once! I'm just more of a 1/2a guy than anything else. So that's pretty much the reason for the size.
Offline bob whitney
« Reply #14 on: May 26, 2020, 11:53:35 PM »
Rod.
I still have all of Wayne's engines except for the one Keith has Rad
rad racer
« Reply #15 on: May 27, 2020, 01:55:19 AM »
Danish,
I used 4140 for cranks. Machines just fine. Haven't gotten one to the running stage so I can't say anything about reliability.
A few different engines so far:  A modified 1/2A Dragon from Clough plans while in High School; a custom 1/2A motorcycle engine based on a Cox piston and cut down cylinder (made into a liner); and a 2x-sized Morton radial.
My Dragon used a 2024 piston with a tiny compression ring. I bought 4130 tubing to make the liner, but the lathe available did not have sufficient stiffness to bore the ID.
I made a fixture to offset-machine the crank pins in place, instead of using a 4-jaw chuck. Used multiple setscrews to dog the part to the fixture. It worked fine.
I agree with Pat that straight knurling could produce the splines on Cox cranks. However, if you are not familiar with knurling, be aware that it puts much higher tool loads on a part than most other machining. I don't know for sure if Cox knurled or broached these pieces. You may need a specific sequence for success as well. For example, N-condition rough machine, knurl, heat treat, then grind.
Carbide inserts may be a bit bulky for smaller parts. Also, they often do not have positive rake, so the tool pressure is higher. Might make it tougher to prevent chatter and hold tolerance on small parts.
Sounds like you are having fun!
The Divot
Offline Dane Martin
  • heli pilot BHOR
« Reply #16 on: May 27, 2020, 08:34:35 AM »
Thanks guys. Let's face it, if it doesn't work... it's still really fun. From my current plans, I'll only be using carbide on the crank itself. Everything else is "softer" metals.
McDivot, I think for this project I'm going to can the knurled crank. The taper seems to be the easiest way with what I currently have.
I'll upload pictures of my progress so far.
Tim, I'm also taking a cue from you about a wrist pin. I'd much rather do that than try to make a ball / socket!!
« Reply #17 on: May 27, 2020, 09:20:09 AM »
Oh, well then -- carry on!  And let us see the results!
... I agree with Pat that straight knurling could produce the splines on Cox cranks. However, if you are not familiar with knurling, be aware that it puts much higher tool loads on a part than most other machining. ...
You can get knurling tools that clamp the knurls onto the part, instead of pushing against them.  So instead of the force coming from the cross-slide and being opposed by the part, the force of the top wheel is opposed by the bottom wheel.
It's said to be gentler on the parts and the lathe -- and certainly looks like it.  I can't compare: I have a cheap lathe, so when I got knurling tooling I just got the clamp style.
Offline Dane Martin
  • heli pilot BHOR
« Reply #18 on: May 27, 2020, 09:29:47 AM »
I agree. Knurling is a cheap mass production method, not a precision connection. Especially if you need to dismantle it later. Conical & cylindrical holes are easy to make, just keep the cutter exactly on centerline.
I found some old pieces of Mahle #138 piston material (18% Si). If you want you can have them. It's just in a bit weird shape so you'd have to start with band saw:
L
I would definitely take that!  From that scale there, it looks like I could make several pistons.
« Reply #19 on: May 27, 2020, 07:12:16 PM »
Dane.  That sounds like a great project!  Not a fun project, but a great one anyway.
I think the splined shaft on Cox engines is a poor idea.  Great as long as you don't bugger up even the smallest part of it.  Once a spline is even slightly damaged, it will then require massive number of Newtons to get it back on.  Once wrecked, the drive washer is next to impossible to get back off.  Others have suggested a taper shaft.  Great.  That can't get stuck.
90 years, but still going (mostly)
Offline pat king
    • PDK LLC
« Reply #20 on: May 27, 2020, 09:10:21 PM »
If the knurl (spline) is damaged the engine is probably very badly damaged unless someone has gone "hammer mechanic" on the engine.  The crank to prop driver is not desired to be a slip fit as would be with a spline. Cox made millions of engines with a zero clearance crank to prop driver fit. So, I don't think we can say that is a bad way to build a 1/2A engine.
You say a taper shaft can't get stuck, that is not true. Axles on Ford banjo housing rear ends were tapered. When we would shear an axle key on our coupe the hubs were almost impossible to remove. We were never able to get them off at the track. A puller would only break the hub, The only way to get the axle-hub apart was to remove them from the rear end and use a hydraulic press to remove the axle. They were not friction welded. The axles were hardened steel the hubs were cast iron.
Pat
Pat King
Monee, IL
AMA 168941
Offline Dane Martin
  • heli pilot BHOR
« Reply #21 on: May 27, 2020, 09:14:45 PM »
Thanks Floyd. I figured I've done enough case, muffler and engine reconditioning for friends and family I should just combine it all into making one.
So if everything goes according to plan, I cut a crank blank from this grade 8 bolt. I'm completely winging it here. Looks goofy, but I'm trying to make the excess of the crank part of its own offset fixture. I only have a 3 jaw on the chuck now. I found a 4 jaw on Ebay... I'm watching it.
Offline Dane Martin
  • heli pilot BHOR
« Reply #22 on: May 27, 2020, 09:16:44 PM »
Just as a practice run, I'm making a crank for my cs .061. It suffered  a 50 percent crank  departure.
« Reply #23 on: May 27, 2020, 11:33:35 PM »
Danish,
Looks like lots of fun.
That machine ought to have plenty of horsepower to turn 1/2A cranks! Based on the picture, I'd try a tool with a smaller tip, if you can.  Try to have clearance behind the cutting edge so you are not dragging an edge. Hone the edge that is doing the work. You can stiffen the setup by running the live center into the bolt head. (You may be giving up some stiffness chucking on the threads, as well.) If you get rid of any chatter and get good tool geometry it is a lot easier to get the tolerance and finish you want.
A soft wheel or diamond hone would help dress the edges when using brazed carbide inserts.
I'll have to go look for these "self-supporting" knurling tools that guys are talking about. I haven't used one of those before.
McDivot
PS--The FAA got on me years ago with my excessive crank departures. They apparently rated my Mouse racing by whether all of my departures were on-time or not. I finally got to the point--after a lot of work--that all of my departures were on-time. One every heat. Usually right where they wanted it after the pit stop. So oddly, my government rating went up, but my scores (DNF) did not.
Offline Dane Martin
  • heli pilot BHOR
« Reply #24 on: May 27, 2020, 11:43:17 PM »
McDivot! So while going through my stuff, I found that my live center doesn't fit in my tail stock. It's too large. You're right about the tool being too large. I went back and forth several times at a slower rpm, and SLOWLY fed in the tool. I got a reasonable cut for the poor processing I'm using, but I'll continue to inventory my tooling and set up properly.
Thanks buddy
Offline pmackenzie
  • Pat MacKenzie
« Reply #25 on: May 28, 2020, 04:35:56 AM »
If I had to choose one cutter for general work, I would take a boring bar, as stiff as possible, with insert shaped like in picture below. They are easy to grind sharper when needed, and the geometry gives a small relief angle to both x and y directions. It improves the surface quality.
CCGT, high positive?
Normally high positive is for non-ferrous.
MAAC 8177
Offline Dane Martin
  • heli pilot BHOR
« Reply #26 on: May 28, 2020, 06:41:48 AM »
I didn't use that giant tool to cut, I just tried to clean up the 90 degree corners, without having to change tools ,  but i see what you mean. I have a nice tool grinder. It was just a lot of work to get it out yesterday. My garage is a mess. I probably should clean it and get it organized before I started this project!
Offline Dane Martin
  • heli pilot BHOR
« Reply #27 on: May 28, 2020, 07:11:25 AM »
I have the lathe in the video. Also I watched the video again and saw a few things I probably shouldn't be doing, and some things I should add. Time for a reeducation!
« Reply #28 on: May 28, 2020, 08:20:20 AM »
...You say a taper shaft can't get stuck, that is not true. Axles on Ford banjo housing rear ends were tapered. When we would shear an axle key on our coupe the hubs were almost impossible to remove....
The degree of taper makes a big difference.  Those Ford axles have a taper of something like 5 degrees or 10 degrees, and there would have been bits of key in there to jam things up.  The tapers I see on model airplane engines are more like 20 or 30 degrees.  I'm not saying they won't get stuck -- but they should be less likely to.
« Reply #29 on: May 28, 2020, 11:54:05 AM »
... or you could go with a threaded hole and stud arrangement which would cut down on material removal. ...
An advantage to this arrangement is that when you bork the plane, there's a good chance that the stud will bend but not the crankshaft.
I deleted the part where you mention 12-32.  If Dane is building an 049 then he probably doesn't want bigger than a #6 thread.  Cox uses a 5-40 on theirs, and the Norvel 049 and 061 engines use M3.5 (Edit: or M3).  If it were me I'd probably use a 5-40 just because of the sheer weight of all the Cox stuff I have around.
Offline Dane Martin
  • heli pilot BHOR
« Reply #30 on: May 28, 2020, 12:12:32 PM »
I'll be drilling and tapping for 5-40. Like everyone else, I got plenty of Cox parts laying around.
MM,
I'm drawing up how you've described the offset fixture. Would it be unwise to make a clamp collet to hold the shaft off center that aligns the crank pin? The collet would be held in the jaw rather than a bolt on? Something like this crude drawing?
« Reply #31 on: May 28, 2020, 12:20:41 PM »
Dane, these may help.
Drill an offset hole in some round stock, then make a slit from hole to the stock edge, across the widest part of the remaining stock.  If you make the hole a slip fit or light press fit on the crank, then when you tighten up the holder in your 3- or 4-jaw, it'll tighten the holder on the crank.
In my case I didn't care about getting the stroke exactly right, so I just kind of threw things together.  With a 3-jaw you set the crank throw with the hole location in the stock.  With a 4-jaw (or a 3-jaw and shim stock) you can use a dial indicator with enough range (or if you use an indicator plus the readout on your cross slide) to get the stroke more accurate.
This was for a TD 09 rebuild; I was aiming for exactly 1/2 inch stroke, plus or minus a mile.
« Reply #32 on: May 28, 2020, 12:22:31 PM »
I suppose you could get fancy, and drill and tap the holder for clamping screws.
Offline Dane Martin
  • heli pilot BHOR
« Reply #33 on: May 28, 2020, 12:36:59 PM »
Ah, see that's what my half @$$ed picture was alluding to. I believe that would be the simplest thing for me to do without restoring to buying a bunch of stuff. I am not tooled up for this... I'm working on it. And I will be. But a little at a time.
Thanks for the pics
Offline Dane Martin
  • heli pilot BHOR
« Reply #34 on: May 28, 2020, 01:31:00 PM »
If you think your jaws will hold the collet straight, then your offset pot chuck will work. Not sure how you would make one without a 4 jaw.
Motorman 8)
I did find a nice condition 4 jaw on the 'bay. I think I'm going to bid on it anyway. It would be a nice addition
« Reply #35 on: May 28, 2020, 01:44:45 PM »
Motorman 8)
In my top picture that's a 1" diameter hunk of aluminum with a piece of stock roughly 1/4" think behind one jaw, to offset the aluminum round.
« Reply #36 on: May 28, 2020, 03:29:36 PM »
Dane, I just took another look at your sketch, and it looks an awful lot like an Owen's Mate, with plans in the Motor Boys International plans book.  You could do worse than take inspiration off of that engine, I think.
Offline Dane Martin
  • heli pilot BHOR
« Reply #37 on: May 28, 2020, 03:48:55 PM »
Awesome. Thanks for the tip. I'll look it up!
Offline Dane Martin
  • heli pilot BHOR
« Reply #38 on: May 29, 2020, 03:46:38 PM »
Ok first of all. I want you, my friends, to take notice that I listen. I shimmed up my tool to be even with the tail stock center. I believe I have my tool geometry set correct. I definitely got a better finish while making my offset collet.
« Reply #39 on: May 29, 2020, 03:57:40 PM »
For an even better finish, round off the end of your tool.  I can't remember the right name (the real machinists will), but there's a round-nosed tool profile that's specifically made for nice finish cuts.  The idea is that a sharp-point tool is going to make a 'V' groove; a round-nosed tool is going to make a lot of really shallow overlapping 'U' grooves.
Offline Dane Martin
  • heli pilot BHOR
« Reply #40 on: May 29, 2020, 04:23:54 PM »
Will do Tim.
I got the crank pretty well cut out. Not pretty. But, I'm gonna pretend for my first one it's ok. The fit is good, everything is straight. So, I guess it's going oooook. I definitely need more practice. But that's what this is! Thanks everyone for the help and advice. Here's a very quick video update.
Offline Dane Martin
  • heli pilot BHOR
« Reply #41 on: May 29, 2020, 07:21:54 PM »
Well through my desire to learn the proper ways to do things... I happened upon this. I just so happen to have a compound tool reset so now I can accurately cut my crank taper!
Now the question... can I make the prop drive and cut the taper with a sharp reamer, and then just copy that angle on the shaft? Or is there a pre existing known angle I should be using?
« Reply #42 on: May 29, 2020, 09:09:50 PM »
I don't think there's a magic number -- I'd go look in my MBI International Plans Book and shamelessly copy something.  Less of an angle will be more likely to bind; more of an angle will be more likely to spin when you're running the engine (this is considered an advantage on "sport" diesel engines, because it can save the crank when the engine's in hydraulic lock and some idiot goes at it too hard).
When I did mine, I just cut the taper on the shaft, then cut the taper on the prop drive without changing the setting on the compound.  That's not the repeatable way to do it, but it certainly makes a matched pair of parts.
Offline Dane Martin
  • heli pilot BHOR
« Reply #43 on: May 29, 2020, 10:14:17 PM »
Tim, I'm really liking this Owens Mate. It's a good inspiration for ideas.
Offline Dane Martin
  • heli pilot BHOR
« Reply #44 on: May 30, 2020, 12:28:32 PM »
I should have drilled out the pilot for the front first, yes. But with the aluminium collet I made to hold the crank, it wasn't "that" bad. I ended up with a taper of 40 degrees on the crank tip, and tapped it for a 5-40
It's not a professional job by any means. But it's ready to put back together and run.
Offline Dane Martin
  • heli pilot BHOR
« Reply #45 on: May 30, 2020, 07:25:02 PM »
Well not a monumental failure, but not flyable. My intake window is not big enough. I purposely made the window and the crank center slightly undersized. That sounded reasonable, because I think it broke originally due to how thin the crank was. But, doesn't really draw fuel as well. Once I got fuel to it to lubricate the crank, it feels normal. Nice and loose. But it runs. So there's hope for the next one.
« Last Edit: May 30, 2020, 09:29:17 PM by Dane Martin »
Offline Dane Martin
  • heli pilot BHOR
« Reply #46 on: May 31, 2020, 07:56:28 AM »
It's not. There's just no needle. If I get out in a sweet spot it'll run the tank out no problem. It doesn't seem to be getting hot anywhere
Edit; see below where I eat my words
« Last Edit: May 31, 2020, 09:08:46 AM by Dane Martin »
« Reply #47 on: May 31, 2020, 08:27:06 AM »
It sounded like you could pull a small, relaxed, sport free-flight with that, if you could get it to hold a needle setting.  Something designed for a 1950's 049, or a TD 020.
Flying engine first, fire-breather second...
You could put in a smaller venturi to match your smaller crank -- they'd still be undersized for the transfer ports (assuming everything was nicely balanced), but you'd have better needle response, and maybe something that would run.  You could just do a quick & dirty insert with a piece of wood, for a test.
Did you check the intake timing?  A smaller window would reduce the intake time, which up to some point (that I don't know, but I'll bet it depends on the porting) should make for easier starting and lower-speed tractability -- but if you put it too far over one way or another it'd mess things up.  It would be good to check your work on that.  An A/B comparison of the old and new intake timing may help you figure things out (or you could post it, we seem to have experienced engine modifiers here).
You could modify the crank easily enough.  You could open up the window with a Dreaded Dremel Tool, or you could figure out a work holder for it in your mill.  Opening up the hole would only take chucking the crank in a 3-jaw.
Offline Dane Martin
  • heli pilot BHOR
« Reply #48 on: May 31, 2020, 08:31:22 AM »
Well you see, that's the problem. I don't have an old crank to work with. Just a broken nub that I was trying to get measurements from. I figured I had the important part, the crank pin side.
That was the whole start to doing this. To see if I could get it to run again. With the exception of the no needle ability, it's pretty much still a terrible engine. It just used to needle a lot better!
« Reply #49 on: May 31, 2020, 08:39:37 AM »
Are you saying it was a terrible engine before?  So you haven't lost much?
You may have also have introduced a crankcase leak -- I would think (someone correct me if I'm wrong here) that you'd want the crank to be just a bit tighter than a good running fit initially, to give it a chance to wear in.  So if you start with the right clearance for "after it's broken in" then it may be leaking now (or will be).
My approach (and I'm trying not to push -- really!) would be to experiment with getting the most you can out of that part, for the learning experience, and then move on to the next one.
