  • June 21, 2025, 08:18:36 AM
Author Topic: What makes a good stunt engine?  (Read 2482 times)
Offline frank mccune
« on: November 04, 2015, 04:44:52 PM »
     Hello All:
     What is needed to make an engine run well for Stunt to give a 4-2-4 engine run?
     For example, if one takes a RC engine and converts it to be  a Stunt engine, how is the "timing" altered, head shape changed, compression ratio changed etc. I think that I have an idea as to how to make an engine go faster via modifications but the question came up as to how is an engine altered to be a good Stunt engine.  I have heard that a Stunt engine produces more torque but at a lower rpm etc.  I have an engine that was altered to only run in a 4 cycle mode at all times.  I have not personally flown this engine but a friend of mine who had the same engine said that his would only run in a 4 cycle.  He did not like the steady 4 cycle and got rid of the engine.
     Any thoughts?
        Tia,
        Frank McCune
Offline Chris Wilson
Re: What makes a good stunt engine?
« Reply #1 on: November 04, 2015, 06:26:41 PM »
The best answer to this question that I have seen to date is that a good stunt engine must have the ability to accelerate rapidly from a loaded speed condition back to a non loaded one.
Now the 'how' of doing this is bound to vary.
"I have an engine that was altered to only run in a 4 cycle mode at all times"
Must have been a four stroke then.
MAAA AUS 73427
« Reply #2 on: November 04, 2015, 07:30:03 PM »
     Hello All:
Why are you asking that question as if it's synonymous with "what makes a good stunt engine?"  When I go to contests, the engines that exhibit a 4-2-4 run are in the minority, even among engines.  Discounting electric and four-stroke engines, there's basically four ways to skin this cat:
  • Big baffle-ported engines with a 4-2-4 run.  This is not to be totally discounted, but it's not most engines around here.
  • Muffled Schnuerle-ported engines running in a "wet" 2.  This is the most common in Beginner through low Expert.
  • Piped Schnuerle-ported engines (also running a "wet" 2).  This seems to be the most common in Expert-expert ("Expert-expert is someone who has a chance of making it into the top 20 at the Nats.  "Low expert" is people that are too good for Advanced, but whom do not make Paul Walker or Brett Buck quake in their boots when they walk into the circle.
  • Big baffle-piston engines running in a solid 4-stroke.  This is probably in second place in Expert-expert
     Any thoughts?
Don't cut up your engine.  Probably the best thing to do with an "RC engine" (which is most likely a Schnuerle-ported 2-stroke) is to put a venturi and a flat prop on it and see if it'll work in a "wet-2" run, maybe with a pipe.
Just today I got the venturi & adjustment sorted out on my latest ride.  It's an OS 46LA that's had its carburetor removed and a venturi bunged into place, and the right combination of prop/venturi/mixture applied so that it'll pull the plane through the air.  This on a 64 ounce, 670 square-inch airplane.
« Reply #3 on: November 05, 2015, 12:51:58 AM »
     Hello All:
 A 4-2 break engine hasn't been a mainstream stunt engine in the US for close to *30 years*. The gold standard of stunt runs is a completely unmodified RC pattern engine - the OS 40VF. you *do not want* to try to modify most current engines for a 4-2 break run, all that does is lose all the power.
Record (NATS Open Championships since 1990)
20 piped (PA/OS VF/RO-Jett)
3 4-2 break (1 ST60, 2 Discovery Retro 60)
2 electric
1 4-stroke  (Saito 72)
  And in the cases where the 4-break engine won, it was the only one among the contenders. If you want a good stunt engine, get a PA, RO-Jett, or OS VF.
« Reply #4 on: November 05, 2015, 05:54:53 AM »
       Hello All:
       Thanks for all of the replies.  I will have to soon learn that I am living in the past as far as Stunt engines and inflation are concerned.
      I see the modern engines running a wet 2 cycle with a flat prop as the way to go nowadays.  Alas alack, I looked into my crystal ball the other day and saw the glow engines , Diesel, and gasoline engines being replaced by.............electric motors!!!!  I think that one can take that idea to the bank!
     Can you see from my posts that I have been away from model airplanes for about 3 decades? Lol
        Be well my friends,
        Frank McCune
« Reply #5 on: November 05, 2015, 10:32:59 AM »
Hey Frank:
Prognostication is always iffy, but I think that IC engines are going to be around for a while, just not in as great of numbers.  The 46LA is gone because from the RC'ers perspective it's a gutless wonder -- it was designed to be easy to handle and inexpensive, but as electrics got cheap enough it was simply overtaken.  The 46AX has almost twice the power of a 46LA, makes more money for OS, and will probably be around for a while.
If you're going to fly a 40-sized RC plane you need a special place to do it, whether it's IC or electric powered.  I think this is going to keep the space open for slimers, at least for the time being.
« Reply #6 on: November 05, 2015, 01:26:02 PM »
Hi Frank,
If you want to stay in the past and use a 4/2 break with power then try spark ignition.
Modern battery technology has brought battery wieght right down too.
MAAA AUS 73427
« Reply #7 on: November 06, 2015, 07:00:11 AM »
     Hello Again:
     Yesterday, I spent an afternoon flying Stunt and Sport.   I came away with some new ideas as to what makes a good Stunt engine.   will attempt to elaborate about my opinions below.
     There was a LA .40 and a LA .46 engines in use that impressed me greatly.  They were instant starters that ran flawlessly.  To get them to be a "perfect" Stunt engine three things were done to them:
    1. The prop was an 11x5 on the .40 and the prop on the .46 the prop was an 12x6.
    2. The needle valves were set to run in a wet 2 cycle.
    3. The airplanes were large enough to provide the desired airspeed at all times.
     These were box stock engines with no modifications that provided perfect Stunt runs! It could not get any easier!
     I got sucked into thinking that I needed a modified engine that would be a perfect Stunt engine but have since learned that my FOX .40 Stunt circa 1972, my OS .35 Stunt, and OS .40 S give what used to be a nearly perfect  4-2-4 stunt run of days gone by.  I would guess that there are many other engines that perform as well as the OS LA series without any modifications by engine tuning experts.  What engines did you fine that worked well without any modifications?
     Lesson learned was to FIRST try your existing engine to determine if you are able to extract the optimum performance from it by experimenting with the fuel, plugs, props, needle valve settings, line length etc before investing in a custom tuned or custom engine. Are you satisfied with your findings? My next project is to take some of my RC engines and wire the carbs open and see if they will work as a suitable Stunt engine.  I may be pleasantly surprised. Lol
     I think that I have ben making a mountain out of a molehill and overthinking my Stunt engine needs.  Has anybody else made this discovery?
        Aint this hobby interesting?
        Frank McCune
« Reply #8 on: November 06, 2015, 07:51:26 AM »
Some of us are still stuck in the past as far as stunt engines go. I seem to be stuck in 1948. I still love it when gas prices go down as my fuel costs go down too.
