This is as much a question as comment, but aren't SuperTigres designed to have an interference fit between the cylinder liner and the case? Seems I remember reading about someone getting aggravated trying to disassemble a ST.60, and finally got the liner out. before putting it back together, re releaved some material from the outside of the liner or the bore of the case for an easy slip fit, and the engine never ran good after that. The reasoning being that no heat sink from the liner to the engine case? I might have even heard that from Tom Lay. Just curious.
Thanks a lot,
