  • July 14, 2025, 04:00:11 PM
Author Topic: Milled heads pics for Charles  (Read 4579 times)
« on: May 05, 2016, 03:42:20 PM »
These were slick heads with no fins, some cut before or after anodizing
Huge difference in performance in the 40 engine with these as opposed to the no fin heads
Re: Milled heads pics for Charles
« Reply #1 on: May 09, 2016, 07:12:24 PM »
Randy,
I just saw this.
WOW! Really nice work, they look store bought!  H^^
I'm guessing you had them anodised after the tooling, correct?
The one on the end has a solid area, could you please explain that head?
Thanks for that BTW.
Charles
« Reply #2 on: May 09, 2016, 09:06:07 PM »
Randy,
I just saw this.
Charles
Hi Charles  as  I stated  I cut some before and some after anodizing, the  head with the corner left goes to the front intake side of the motor.
Some also have fins cit into the side of the head, as well as the  top
« Reply #3 on: May 09, 2016, 09:21:34 PM »
Randy,
If I decide to keep that Enya Classic, I'll send you the head. You do do great work!  H^^
You can have it anodised after the tooling?
Can you have small stuff anodised? Chromed?  ;D
Charles
« Reply #4 on: May 09, 2016, 10:00:26 PM »
Randy,
Charles
No I used to, but I do not do that  any longer
Offline Bill Morell
« Reply #5 on: May 10, 2016, 08:20:40 AM »
Seems like a easier alternative for this would be to simply use a head from the older 5224?
Bill Morell
Vietnam 72-73
« Reply #6 on: May 10, 2016, 09:02:03 AM »
Bill,
Exactly, thank you.
With that second head you could test runs.
Are they available new?
Offline Balsa Butcher
  • High Desert Flier
« Reply #7 on: May 10, 2016, 03:08:01 PM »
Shtterman at the E-Bay "Control Line Store" lists them new. Order the low compression one for stunt.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Bill Morell
« Reply #8 on: May 12, 2016, 10:55:42 AM »
Bill,
Exactly, thank you.
In all honesty I would just run it as is. Enya hasn't been in business all these years for nothing. I haven't seen anything but quality engines come out of their shop.  See how it runs and then make a decision.
Bill Morell
Vietnam 72-73
« Reply #9 on: May 12, 2016, 01:55:03 PM »
Thanks Bill,
That's good advice, I'll take it!
I'm thinking of designing a Fokker Dr-1 for this engine.
36" in span, possibly 42" in span.
I'll look for a good three view or find a set of plans.
Thanks for the reply.
Charles
