  • June 19, 2025, 11:34:08 AM
Author Topic: Nitro  (Read 6359 times)
Offline Russell Shaffer
Nitro
« on: March 22, 2006, 08:16:34 PM »
How much real benefit does one get from higher nitro percentages?  I always believed that 5% or so was plenty for .35 sized sport engines, and 15% was half A power.  Only the speed and combat guys used more.  Now, what would be the opinion today?  Am I right or totally off base?
Russell Shaffer
Klamath Falls, Oregon
Offline L0U CRANE
Re: Nitro
« Reply #1 on: March 23, 2006, 12:24:06 PM »
Russell,
Nitro % has become a very handy way to fit the engine to the task lately. Even in Stunt, where modern machining technology has allowed a major change in how recent engines run...
Typical fuel for an ABC, AAC or ABN modern schneurle engine starts around 10% nitro, 10% or 11% each castor and synthetic oils. Some engines run best with no castor, btw.
Nitro juggling can restore the desired 'run' at fields at different altitudes, or when temperatures reach seasonal extremes. Hot summer day, vs. cold winter day, e.g.
Nicely fitted engines might just run cooler with some added nitro in the blend. Nitro increases fuel consumption as well as power; the extra liquid flushing through the engine may help cooling. Someone must have a better explanation than that...
The recent Russian small engines (NorVel or AME, particularly) come with instructions suggesting that 15% nitro fuel is about a practical minimum for useful operation.
So, 5% for mid- to large-size engines isn't the basic setup anymore. NorVel/AME advise that 35% is about the practical max for dependable engine life. Most other engines live somewhere between those extremes, even Fox Stunt 35s.
(Remember, though, an iron-on-steel Fox 35 still needs ~28%-29% castor for long dependability.)
\BEST\LOU
Offline Joey Mathison 9806
Re: Nitro
« Reply #2 on: March 23, 2006, 08:25:56 PM »
AMA c/l speed is 10% nitro supplied. i have gone 201.94 mph in d speed. verses unlimited nitro days the head volume is increased(less compression) and the prop length and pitch decreased. i use 10%on all my sport planes also.
200 mph man ama#9806 joey mathison
Re: Nitro
« Reply #3 on: March 25, 2006, 07:44:58 AM »
It has been the same with the control line racing events.  10% nitro and no more.  Anyway the planes are faster than when they ran unlimited nitro.  DOC Holliday
Offline RC Storick
Re: Nitro
« Reply #4 on: March 26, 2006, 11:46:20 PM »
Nitromethane…..everybody knows it’s there, but few, it seems, really know much about it. Although most seem to know - at least vaguely - that’s its primary purpose is to add power, we still get an occasional call or letter asking, "Why do you use it in model fuel?" At best, there is much misinformation regarding this somewhat exotic ingredient. Let’s see what we can do to clear some of it up.
Nitromethane is just one of a family of chemicals called "nitroparaffins." Others are nitroethane and 1-nitropropane and 2-nitropropane. Nitroethane can be used successfully in small quantities. (Top fuel drag racers, which generally run on straight nitromethane, sometimes add a little in hot, humid weather to prevent detonation.) At one time, nitroethane was only about half as expensive as nitromethane, but its cost now is so nearly the same, using it to lower cost is hardly worth the trouble. Neither of the nitropropanes will work in model engine fuel. Incidentally, nitromethane is made of propane, in case you didn’t know (and I’ll bet you didn’t).
Yes, NITRO = POWER! But….there are conditions and contingencies. First of all, it doesn’t add power because it’s such a "hot" chemical. Not at all. This may come as a surprise to most readers, but the methanol (methyl alcohol) in the fuel is by far the most flammable ingredient….nearly twice as flammable as nitromethane. As a matter of fact, if nitro were only 4 degrees less flammable, it wouldn’t even have to carry the red diamond "flammable" label!
In actuality, nitromethane must be heated to 96 degrees F. before it will begin to emit enough vapors that they can be ignited by some sort of spark or flame! (I demonstrated this not long ago to a friend by repeatedly putting a flaming match out in a cap full of nitro. I might add that he insisted on standing about 20 feet away during the demonstration.)
So….how does it add power? We all know (I think) that although we think of the liquid part substance we put in fuel tanks (in our automobiles or model airplanes) as the fuel, in truth, there is another "fuel," without which the liquid part would be useless. Remember what it is? Right….just plain old air (in reality, the oxygen in the air).
Every internal combustion engine mixes air and another fuel of some sort….in our case, a liquid…glow fuel. The purpose of the carburetor is to meter those two ingredients in just the right proportions, and every individual engine has a requirement for a specific proportion of liquid fuel and air. Try to push in too much liquid without enough air, and the engine won’t run at all. That’s the purpose of the turbocharger on full-size engines….to cram in a lot more air than a simple carburetor or fuel injection system can handle.
Now…..suppose we were to find a way to run more liquid through our model engines without increasing the air supply? That would add power, wouldn’t it? Well, guess what….we can! An internal combustion engine can burn more than 2 ½ times as much nitromethane to a given volume of air than it can methanol. Voila! More Power! That’s how it works, and it ain’t all that complicated. Nor do we have to spend a lot of time thinking about it in the course of a normal day’s stunt flying.
However, there are some factors we do need to consider. As a practical matter, virtually all our everyday stunt flying can be done on model fuel containing from 5% to 15% nitromethane. If you’re flying something like a trainer or a similar model, there’s probably no reason why 5% won’t work perfectly well. Need a little more power? Move up to 10% or 15%. In most of our stunt engines today, I really wouldn’t recommend going any higher than that. It probably won’t hurt anything, but it won’t do you much good, either.
We sell more 15% fuel than any other single blend, and for good reason. Most of the popular engines on the market today are built to run on something very near that blend. Typically, European engines will successfully run on lower nitro blends, because they are built to do so. Why? In Europe, nitro can cost between $150 to $200 a gallon! Reason enough?
Nitro does more than just add power. It also helps achieve a lower, more reliable idle. One good rule of thumb for checking to see if a particular engine needs a higher nitro blend is to start the engine, let it warm up for a few seconds, set throttle to full idle and remove the glow driver. If it drops rpm, move up to a 5% higher nitro blend. If there is no discernible drop, you should be fine right where you are.
One of the most popular misconceptions is that by adding substantial nitro, the user will immediately achieve a huge power jump. Just ain’t so. Most will be surprised to learn that in the 5% - 25% nitro range, you will probably only see an rpm increase of about 100 rpm static (sitting on the ground or on a test stand) for each 5% nitro increase. In the air, it will unload and achieve a greater increase, and it will probably idle better, too.
My pet rule is this: If you have a model that’s doing well, but just isn’t quite "there" powerwise, go up 5% in nitro. If that doesn’t do it, you need a bigger engine, not more nitro!
Most of our popular sport engines in use today aren’t set up to run on much more than 15% or 20% nitro. Increasing the nitro has the effect of increasing the compression ratio, and each specific engine has an optimum compression level. Exceed it and performance will probably suffer, not gain, and the engine will become much less "user friendly."
High performance racing engines, for example, are tuned entirely differently….compression ratio, intake and exhaust timing etc….and are usually intended to run on much higher nitro blends. One exception, of course, are racing engines used in certain international and world competition (FAI). By the rules, these engines are not allowed to use any nitro at all, and they go just as fast as those that run on 60 or 65%! The first question that comes to mind, then, is, "Why aren’t all engines designed to run on no nitro, so we can all save a lot of money?" Ask any of the world-class competitors. Those engines are a serious bitch to tune and run, and are definitely not user-friendly! In fact, they are well beyond the skill levels of most average flyers. There’s a price to everything.
Another statement we read or hear frequently is that nitromethane is acidic and causes corrosion in engines. It isn’t acidic, and the manufacturers say it doesn’t happen…..can’t happen. However, at least one noted engine expert and magazine writer insists that it does. Flip a coin. (I once asked Dave Shadel, 3-time World Pylon Champion, and a fellow who works on more high performance engines than anyone I know, how frequently he encounters rust in engines that have been using high nitro blends. His answer? "Never.")
Why does nitro cost so much? While I have no clue as to the cost of manufacturing, other than it takes a multi-million dollar investment in a large refinery to produce it, there is one pretty good reason: There is only one manufacturer of nitromethane in the Western Hemisphere. Figure it out for yourself.
Also (and this will come as a big surprise), our hobby industry only consumes about 5% of all the nitromethane produced; and full-size auto racing about another 5% or so. This means we have no "clout" whatever, and simply must pay the asking price. Where does the rest of it go? Industry. It’s used for a variety of things - a solvent for certain plastics, insecticides, explosives (yes, it was an ingredient in the Oklahoma City bombing) and I’m told it’s an ingredient in Tagamet, a well-known prescription ulcer medication (no wonder that stuff is so expensive!). Please note that while nitromethane is an ingredient in making some explosives, under normal use, it in itself, is not exploseve. (Remember….the guy used fertilizer, too.)
Hardly a month passes that someone doesn’t call to ask, "I hear more nitro will make my engine run cooler. Is that true?" Nope. The higher the nitro content, the higher the operating temperature. Fortunately, in most of our sport engines, the difference in operating temps between 5% and 10% is negligible, and there are lot of other factors (proper lubrication, etc.), that are much more important.
Finally, remember in the beginning of this, we said that nitro adds power because we can burn more of it than we can methanol, for a given volume of air? This also means that the higher the nitro content of the fuel, the less "mileage" (or flying time) we will get. In a typical .40 size engine using 15% nitro, we can usually get a minute to a minute and a half flying time for every ounce of fuel. The Formula 1 guys are lucky to get 2 minutes out of an 8 oz. tank!
What’s the practical side of this? If you go to a higher nitro blend, be sure to open your needle valve a few clicks and reset before you go flying. Otherwise, you’ll be too lean, and could hurt your engine. Conversely, if you drop to a lower nitro blend, you’ll have to crank ‘er in a little.
If you want to see real power a little Propaline oxide or some Nitro Benzine should do the trick. ;D
Online RandySmith
Re: Nitro
« Reply #5 on: March 27, 2006, 11:07:27 AM »
Sparky the article you have there was written by Don Nix,
Some of what he wrote is true and  some of it is not.
Don Wrote this while in the fuel business  and his writings are  very slighted that way. He was also talking basically about RC sport engines which run very differently than the way we run C\L stunt engines.
Take for example when he says higher nitro will not make an engine run cooler but hotter. In 99% of the times we add nitro, we also run the motor richer, making it run cooler. Not the case with RC sport flyers.
I have gone thru this before so I won't even comment on some of the rest of it
Offline RC Storick
Re: Nitro
« Reply #6 on: March 27, 2006, 11:15:57 AM »
Edit what is not true and add what is.
