  • June 23, 2025, 06:24:06 AM
Author Topic: Launch RPM : Old Style 35's ?  (Read 1013 times)
Offline Robin_Holden
« on: January 09, 2010, 11:25:29 AM »
A very Happy New Year folks from a very chilly Charente in S.W.France.
Advice please regarding the expected launch RPM of my 'older ' engines.
I have several older engines , which are usually run on a fuel mix of 25% lube' , usually 18% castor , 7% synthetic with 5% nitro. I am using  MAS 10X6 props' and uniflow R/C plastic tanks. I am also using tongue mufflers.
My 'best/reliable' launch RPM's are as follows :
ENYA 35 [ 5224 ] : Around 9,000.
OS 35S              : Around 8,800.
Fox 35 [ 40th and 50th Anniv'y ]    : Around 8,600. [ With all castor 27% ]
Do these appear about right guys or should I be expecting someting better please ?
Much obliged for any contributions ,
Robin [ ex-pat Brit in the Charente full of ex-pat Brits ]
Offline Manuel Cortes
Re: Launch RPM : Old Style 35's ?
« Reply #1 on: January 11, 2010, 10:51:12 AM »
Hi all.
AFAIK, they seem right figures, approximately between 8.500 and 9.000 (mainly depends on the load fron the prop) is a good launch....might be in the edge between 2 stroking and 4 stroking (more or less) and settle back to 4s after a lap or so.....
Hope it helps.
Regards from Spain
Offline Jim Thomerson
« Reply #2 on: January 11, 2010, 05:47:22 PM »
As said, sounds about right.  I'd suggest you try a handful of different brand props around the size.  Prop makes a lot of difference to how the engine runs and how the airplane flies.  I've been running 11 x 5's on my Fox stunt 35 for a good while now.
Offline Russell Shaffer
« Reply #3 on: January 11, 2010, 06:30:48 PM »
What brand, Jim?
Russell Shaffer
Klamath Falls, Oregon
« Reply #4 on: January 12, 2010, 10:40:06 AM »
Much obliged for the contributions fellas ,
Thanks ,
Robin.
« Reply #5 on: January 12, 2010, 10:55:59 AM »
At the moment I am running a Taipan.  I've run Zinger wides in the past.  An APC 11 x 5 seemed to be a little too much.  An APC 11 x 4 was OK, but not as good as the Taipan.
