  • June 25, 2025, 02:31:00 AM
Author Topic: Stupid question of the day...how much castor?  (Read 1011 times)
« on: September 20, 2010, 07:07:46 PM »
 If I want to increase castor content by 5%, how much do I add to a fresh gallon?
Offline nathan Metzner
Re: Stupid question of the day...how much castor?
« Reply #1 on: September 20, 2010, 07:12:08 PM »
6.4 ounces
Nathan, New guy, Newbie, Youngster, Pleeb, So on and so on
« Reply #2 on: September 20, 2010, 07:13:36 PM »
Actually my bad I didn't take into account the displaced fuel make it 6.1 ounces.
« Reply #3 on: September 20, 2010, 07:24:09 PM »
6.4 ounces
Casual, "good as it needs to be" answer: close enough.
Strictly: Nope.  That is, indeed, 5% of 1 gallon (128oz).  But it's only 4.8% of 134.4 oz, which is what you have after you add castor.
Doesn't make much difference if you're only increasing by 5%.  But if you want to go up 20% it makes a marked difference (25.6oz of castor would bring a gallon of fuel up by only 16.7%).
If you're not afraid of calculators, and you want to increase the castor (or nitro) content of fuel by 'p' percent, then you need to add
v_a = v_s * p / (100% - p)
where v_s is the amount you started with and v_a is the amount to add.
So if you want to add 5% castor to a gallon, p = 5%, v_s = 128 oz, and v_a (by calculation) is 6.7oz.
Just chuck 8oz in there -- it's close enough, and it's a nice round number!
« Reply #4 on: September 20, 2010, 07:29:35 PM »
 Thanks guys, 8 ounces it is. H^^
Offline Rob Killick
« Reply #5 on: September 20, 2010, 09:43:36 PM »
Rob Killick , MAAC 33300
« Reply #6 on: September 20, 2010, 10:28:40 PM »
 That's really slick Rob, Thanks! y1
« Reply #7 on: September 21, 2010, 07:48:37 AM »
Yes it is itbeats me trying to figure out how much fuel needs to be reomved from the gallon jug and then figureing out how much oil to add to that to get my percentages correct. Sorry I messed you up there I went the wrong way with the correction for fuel removed my bad.
