  • July 12, 2025, 09:59:58 PM
Author Topic: blank  (Read 1373 times)
blank
« on: February 17, 2013, 12:48:26 PM »
blank
« Last Edit: September 07, 2021, 07:52:54 AM by Motorman »
Offline Garf
    • Hangar Flying
Re: Cox Fuel
« Reply #1 on: February 17, 2013, 01:12:15 PM »
Cox base fuel formula:
Offline ray copeland
Re: Cox Fuel
« Reply #2 on: February 17, 2013, 01:14:52 PM »
MM, i use Omega 25% nitro with a couple ounces of castor added per gallon. The cox 5x3 or the apc 5.5x2.5 depending on the weight of the plane.
Re: Cox Fuel
« Reply #3 on: February 17, 2013, 01:51:55 PM »
In a large mixing bowl combine...
Re: Cox Fuel
« Reply #4 on: February 17, 2013, 03:01:48 PM »
  We've been running Cox and Norvel engines at Oshkosh on 15% SIG Champion, which they donated for the event, and it's 20% total oil that is half Klotz and half castor. If just running for sport flying that should be easy enough to duplicate with a lot of different fuels, just don't eliminate the castor oil.
Offline Joseph Lijoi
Re: Cox Fuel
« Reply #5 on: February 18, 2013, 10:46:41 AM »
What is Dow Lube XA-1150-6 ?
Synthetic Lube.  Look at the asterisk shipped as Klotz......
Offline Reptoid
Re: Cox Fuel
« Reply #6 on: February 18, 2013, 11:37:14 AM »
It was Union Carbides LB-1150 UCON with additives for use in 2 stroke model engines. No longer available.
       Don
       AMA # 3882
