Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
July 30, 2025, 11:34:25 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Cox 09 fuel tubing size
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Cox 09 fuel tubing size (Read 746 times)
Bootlegger
22 supporter
Trade Count:
0
Admiral
on:
August 09, 2020, 07:23:20 PM »
I am looking for Cox 09 fuel tubing size/availability suggestions from you fellows, obliged
Logged
8th Air Force Veteran
Gil Causey
AMA# 6964
25 supporter
Trade Count:
0
Admiral
Re: Cox 09 fuel tubing size
Reply #1 on:
August 09, 2020, 08:08:37 PM »
What ever fits, seriously. If small is too hard to get on the fittings, use medium. If that's too loose, safety wire it. You only have two choices, small and medium, and you don't even wanna think about large.
Logged
EAA 1038824
john e. holliday
25 supporter
Trade Count:
0
Admiral
Reply #2 on:
August 09, 2020, 08:29:30 PM »
As there is very little room for the Medium to grip I cut a short piece of tubing from the medium and using needle nose pliers I stretch it enough to slip over the fuel line. Seems to hold for me as when I tried wrapping with wire it still slipped off.
Logged
Shawnee, KANSAS 66203
AMA 23530 Have fun as I have and I am still breaking a record.
dennis lipsett
Trade Count:
0
Admiral
Reply #3 on:
August 09, 2020, 08:45:11 PM »
I always used surgical tubing. That nice brown surgical rubber. Get the small tubing and it is a perfect fit. Downside is that the fuel rots the tubing and you will replace it on a regular basis. It was the stuff that was always used in 1/2 a speed when I was a kid in the year ....BC. Check surgical supply sites or nearby stores. Also the really small aquarium plastic tubing works. Same problem though as it must be replaced on a regular basis. The fuel makes it rock hard and if you have to take it off the fuel nipple you might as well replace the tubing
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Jump to:
=> Engine set up tips
