  • July 31, 2025, 08:41:58 AM
Author Topic: Cox 09 fuel tubing size  (Read 753 times)
Offline Bootlegger
« on: August 09, 2020, 07:23:20 PM »
 I am looking for Cox 09 fuel tubing size/availability  suggestions from you fellows, obliged    n~ :!
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Cox 09 fuel tubing size
« Reply #1 on: August 09, 2020, 08:08:37 PM »
    What ever fits, seriously. If small is too hard to get on the fittings, use medium. If that's too loose, safety wire it. You only have two choices, small and medium, and you don't even wanna think about large.
« Reply #2 on: August 09, 2020, 08:29:30 PM »
As there is very little room for the Medium to grip I cut a short piece of tubing from the medium and using needle nose pliers I stretch it enough to slip over the fuel line.  Seems to hold for me as when I tried wrapping with wire it still slipped off. D>K
Offline dennis lipsett
« Reply #3 on: August 09, 2020, 08:45:11 PM »
I always used surgical tubing. That nice brown surgical rubber. Get the small tubing and it is a perfect fit. Downside is that the fuel rots the tubing and you will replace it on a regular basis. It was the stuff that was always used in 1/2 a speed when I was a kid in the year ....BC. Check surgical supply sites or nearby stores. Also the really small aquarium plastic tubing works. Same problem though as it must be replaced on a regular basis. The fuel makes it rock hard and if you have to take it off the fuel nipple you might as well replace the tubing
