  • June 17, 2025, 01:46:39 AM
Author Topic: Cox .09 engine  (Read 1088 times)
Offline Bootlegger
Cox .09 engine
« on: September 13, 2021, 07:43:24 AM »
  Got  Medallion 09 Cox engine and can't get the piston and liner to seperate from the block, the exhaust port is real small and the "fork" will not fit in the ex port.  Any suggestions/ideas that will work?  I need to check piston rod slack ... HB~> HB~> HB~> HB~>   I'm obliged.. #^ #^
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bootlegger
Re: Cox .09 engine
« Reply #1 on: September 14, 2021, 01:03:44 PM »
  Got it today, pulled glow plug, found that the cyl had been end milled, used a 3/4" open end wrench and got it to come loose, now to look for other parts..   Much obliged to ALL the members here... D>K :! n~ #^ y1 <=
Gil Causey
AMA# 6964
Re: Cox .09 engine
« Reply #2 on: September 14, 2021, 06:25:08 PM »
I sure hope you didn't distort the cylinder by using a makeshift wrench on it. A hardwood stick through the exhaust port is the safest way + some heat.
I've had a Medallion ,09 and a .15  Both were cranky and hard to start.  Here's hoping you have better results.
