  • July 06, 2025, 06:36:43 AM
Author Topic: Tank adjustment  (Read 1697 times)
Offline Wayne J. Buran
Tank adjustment
« on: September 06, 2006, 04:07:12 AM »
My impact uses a Sullivan rectangular flex tank and I have the adjustment almost there. The powerplant is a Ro-Jett .65 BSRE on pipe. I have plumbed it according to Allen Brickhaus Flying Models article. No problem until the airplane is doing outsides or inverted at which time it slows slightly, enough to feel it be uncomfortable. Please comment on the ajustment of the fuel pickup. Allen also says that the uniflow tube maybe adjusted in and out but doesnt explain the results of that movement. Thanks in advance for your help.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
Re: Tank adjustment
« Reply #1 on: September 06, 2006, 06:09:10 AM »
Wayne
Hi Wayne,
I have found on clunk tanks that rotating the plug withthe fuel/uiflow lines does about the same as moving the tank.  Withthe plane on it's wheels the plug should be rotated so that the uniflow line is above the pick up.  That is on the Hunt/Werwage set up.  I am not sure of how Allen did his, exactly.
Bill <><
Bill <><
Re: Tank adjustment
« Reply #2 on: September 09, 2006, 04:33:07 AM »
Thanks Bill, so are you saying that sitting on its wheels the pickup should go down?
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
Offline Jim Thomerson
Re: Tank adjustment
« Reply #3 on: September 09, 2006, 09:38:17 AM »
The engine thinks it is sucking fuel from the end of the uniflow; so moving the uniflow down will richen the engine inverted, and vice versa.
Re: Tank adjustment
« Reply #4 on: September 09, 2006, 05:09:20 PM »
Wayne
Sitting on the wheels, it should go up.  It pretty much works just like moving a metal tank up.
Bill <><
Re: Tank adjustment
« Reply #5 on: October 04, 2006, 04:39:51 AM »
Bill, finally got to test the adjustment on the tank this past Sunday. Right on the money, first time out. Thanks for the help.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
