  • June 21, 2025, 04:04:55 PM
Author Topic: cough@#$% cough!!  (Read 857 times)
Offline roger
cough@#$% cough!!
« on: June 15, 2008, 01:04:18 PM »
anybody have any plans to build a toung muffler?
roger S?P
Re: cough@#$% cough!!
« Reply #1 on: June 26, 2008, 09:19:18 PM »
I once made some. Started with a fair sized blocks of 6061T6 and ended up with 13 gram tongue mufflers. It was a lot of work, and I used a CNC milling machine. I also decided that I like tube mufflers better...mellower sound, less bark. Some engines don't seem to run well with tongue mufflers, on top of that. Volume is important, as is the amount of "leakage".
You should look for suitable mufflers from the usual stunt sources, such as Randy Smith, Eric Rule, Big Art, Brodak, Leonard Neumann, Jim Lee, RO-Jett, and some I've probably missed.  If you insist, you can make a (heavier) tongue muffler from DuBro exhaust extension stock. The large size fits K&B/Veco .61's nicely, and I seem to think there is a smaller size from DuBro that might fit some .40's.   D>K Steve
Online Dalton Hammett
« Reply #2 on: June 27, 2008, 09:59:30 AM »
Hey Roger ---  I understand that Cardinal Model works in South Vienna Ohio will build tongue mufflers
for any engine.  They have made venturies for me in the past and have been good to work with.
   Dalton H.
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
