  • July 14, 2025, 06:03:39 AM
Author Topic: correct wrench, pliers ?  (Read 817 times)
Offline jim gilmore
« on: March 07, 2009, 08:00:29 PM »
Ok, I know this sounds simple but I was installing the new venturi and spraybar in my os .25 LA. I have a hard time trying to get it snug and was wondering what You all use to hold and tighten the spraybar and the nut ? I do not have any open ends that small and my sockets wount go over the spraybar.
Online Alan Buck
Re: correct wrench, pliers ?
« Reply #1 on: March 07, 2009, 08:24:12 PM »
Jim, Try a 5 or 6mm deep well socket if that does not work use needle nose pliers hope this helps
ALAN E BUCK
« Reply #2 on: March 07, 2009, 09:37:10 PM »
Sears sells Craftsman midget combination wrenches in SAE and metric.  With a set of each, and fairly complete sets of metric and SAE 1/4" drive sockets, most of the time I've got the right tools for the job.  Sometimes it's easier to use a hemostat or needle nose pliers on the spring side.  It can be difficult to get the tools in around the spring, and it doesn't take much force to get the spraybar tight.
Offline Pinecone
« Reply #3 on: March 12, 2009, 01:51:04 PM »
They are called Ignition Wrenches.
Very nice to have around models.
Terry Carraway
AMA 47402
Offline Elwyn Aud
    • Inferalandings Photo Page
« Reply #4 on: March 12, 2009, 03:46:13 PM »
I think 5.5 mm is the correct size. I ground one socket down to where it would fit between the springs without spreading them apart very much.
