Joseph,
One thing you should check is the wrist pin/connecting rod area to make sure that the connecting rod is able to move on the wrist pin. Sometimes if a motor has had dried castor in it the wrist pin can be locked to the conrod and will rotate in the piston, which will cause lots of wear. To check it, remove the backplate, rotate the shaft to bottom center, at this point you should have good access to the conrod. Then grab the rod and try to slide it in and out. If it moves you should be good to go. If it is locked used a heat gun to warm the inside of the piston/wrist pin/ conrod. This will generally loosen it, put some afterrun oil on it and button her up. If after a couple try's with heat if it is still locked you may need to disassemble it or send it to one of the engine guys for proper cleaning.
Best, DennisT
