Thanks, Randy.
The bore is 24mm (mic says 23,960mm for piston) As I said, at the moment we use a ST.60 ring, I don't think Robbie modified it anyhow before assembly. Ring thickness (height) is 0,98mm. The pin is in front of piston (rear exhaust), or actually a couple of millimeters to the left, so the ring gap is in the center. I think Rob only thought of symmetry when he was making the piston.
What's the reason for your recommendation about the pin position?
About the thickness, we've talked about going even thinner as you say, to about 0,6mm (23 thou). Remember the piston lubrification is very good because of the piston ports, and the bore is chromed. I allready got some Rossi .60 rings with that thickness but we haven't tried them yet.
Please send a dykes ring if you find one. Even if it's not good size, it would be good to have an example.
Some people have mentioned that Dykes would be more difficult to start. Should I worry about that?
What is your opinion, which one is best for a stunt engine, a Dykes or a normal ring (or two)?
Lauri
