  • July 14, 2025, 12:53:12 AM
Author Topic: Compare engine power: Brodak 40, OS LA 46, OS LA 40  (Read 9469 times)
Offline Jim Oliver
« on: October 24, 2007, 01:55:57 PM »
Locally, I see folks flying the Brodak 40 with the same props used on the OS LA 46 and LA 40 and tuning the same rpm.  Normally, my B40 uses 4 oz. Powermaster 10/22 for the pattern with the Zinger Pro 11x5 at 9000rpm.  Usually, the OS engines require more fuel to fly the pattern than the B40.
Now, I think that the OS 40/46 will probably turn the prop in question (Zinger Pro 11x5) faster than the B40, but  not with the run characteristics shown by the Brodak.
So---my question:  If one had a model that is slightly large or heavy for the B40 would there be some advantage to using an OS LA 46?  If yes, how should the LA 46 be set up?
I saw Dee Rice fly his stock LA 46 powered R.M. 576 at Memphis but don't know what rpm he ran with the APC 12.25x3.75 prop he was using.
What say you?
Jim
Jim Oliver
AMA 18475
Re: Compare engine power: Brodak 40, OS LA 46, OS LA 40
« Reply #1 on: October 24, 2007, 02:42:59 PM »
Hey Jim,
Can we throw the FP .40 in the mix?
Offline Jim Oliver
« Reply #2 on: October 24, 2007, 03:27:50 PM »
Sure, Paul--the more the merrier!!
I hope to get some answers on this---so far, from my very limited observations, I don't see a power advantage to the LA 46---unless a solid two stroke run is used.
Jim
Jim Oliver
AMA 18475
Offline Ron King
« Reply #3 on: October 24, 2007, 03:34:05 PM »
Jim,
I am far from an expert on these engines, so please take what I say with a grain of salt.
The LA 40 is worthless. I tried several and they are back where they belong: with the RC guys.
The LA 46 is a good engine, even though I am one of the few people on this planet who doesn't like the way they run (wet 2 stroke). I loaned mine out to guys and they were very happy with my engines - happier than I was.  HB~>  The LA 46 is a bored out LA 40, so not only is it a better engine, it's also lighter, so forget the 40. The disadvantage of the 46 is the bigger lines (.018). I certainly notice this and have to adjust for it when flying a smaller airframe.
I have been running the Brodak 40 on my Cardinal profile and it's a better engine for me. It was designed and built for control line and doesn't require as much fiddling.
From what I've seen, the LA 46 may be a little more powerful (after all it was designed for high speed RC), but the Brodak 40 will fly just as well. The 12.25x3.75 is a very nice prop for the LA46. I have been using the APC 11.5x4 "CL Stunt" prop on my Brodak 40 with good results. I also have some Bolly Clubman 11.5x5 props. They are more consistent than the Zinger and give the same run.
The FP engines? Much better quality overall. I wish they still made them. I have a wonderful FP 35 that just purrs. It runs almost as well as my Aero Tiger.  :##
My .02,
Ron
Ron King
AMA AVP District 4
Wannabe Stunt Pilot since 1963
 Amateurs practice until they get it right; Pros practice until they cannot get it wrong.
Offline Ralph Wenzel (d)
« Reply #4 on: October 24, 2007, 03:41:34 PM »
Well, as long as you're including .46s, my choice would probably be a good, solid ST G21/.46 on a REv-Up 12-5 or RSM 12-6 cut to 11˝".  Tough to beat that nice, predictable run . . .
Ralph Wenzel
AMA 495785 League City, TX
Offline Mike Greb
« Reply #5 on: October 24, 2007, 07:20:59 PM »
My La40 runs fine.   Bone stock.  remote nv, stock muffler.  Sullivan oval tank plumbed for uniflow and muffler pressure.  Only filling the tank with just over 3 oz of fuel.
« Reply #6 on: October 24, 2007, 07:58:32 PM »
First off, let me qualify everything I say, I am NOT an expert either with engines or flying but I have learned bunchs from those who are, ok, I fly both the FP 40 and the LA 46. which do I like better, well both.
both have their drawbacks and both have strenghts. the FP 40 seems to work well for me on the apc 11.5 x 4 or the 11x4, I generally launch at 9600 depending on the airframe and tank setup and how much it unloads when launching.
My LA 46, I use the 12.25 x 3.75 APC on it and launch at 9700 with either tanks setup or venting, ie muffler or free air. It doesnt do a classic 4-2-4 in this mode, but it does break. I use powermaster 10x22 fuel to which I add 6 to8 oz of additional castor depending on weather conditions. I have found that the FP is very sensitive to load, blade width and weight. I have far better runs with a wood prop that I carve to mtch the APC 11.25  x 4. It is really happy and breaks well. Moost of my stuff uses the stock muffler because of CG issues and I take out the baffle, as well as open up the stinger tip until I think its going to be to thin.My FP in that setup does a really nice break and it is more along the 4-2-4 style than the LA. THe drawback to the FP is that unless you get the motor loaded in its happy place it will  want to go lean sometimes. this is prop critical in my experience. My experience yiours may vary. The LA is somewhat a plug and play with the 12.25 x 3.75 APC and 9700 RPM. However if you play around with props and rpms, you will find that it will vary its fuel consumption DRAMATICALLY with RPM. I am talking a few hundred rpm high and you will be there an extra 3 minutes a few hundred low and you can run out in th ehourglass, ask me how I know, Now I run the APC , set the needle by the tach and fly. dead on consistant. NOw Pat Johnston flies his LA46 with the .272 venturi and a ST needle, same prop, same rpm and he gets the pattern done in like 3.75 oz of fule, mine takes 4 or slightly less, I use the larger stock venturi and a ST needle.
As I said, my experience yorus may vary, also my FPs get a retiming mod to the boost port, I dont block it.
« Reply #7 on: October 24, 2007, 08:17:32 PM »
My LA40 is a brute but save your 4-pitch prop for stiring paint.  Put an 11-6 PowerPoint on it with 10% Omega or Coolpower - and fogetaboutit.
« Reply #8 on: October 25, 2007, 08:49:54 AM »
As I have stated here several times before when people ask about engines, props and fuel, it depends on what part of this great land you fly in.  Also the time of the year.  Why do the top guns in Precision Aerobatics put in so many flights at the NATS?  It is because it is not the same as it is at home.   I have an OS FP-35 that flies circles around my OS FP 40.  My OS LA 40 flies great now that I have removed the blue coating that was on it.  Have not gotten the OS LA 46 out of the box yet.  Now to the Brodak 40 I have no complaints of any kind with it.  But, each and every engine I have mentioned has its own prop that works the best.  Have fun,  by the way the fuel I use is standard SIG 10% with half & half oil.  DOC Holliday
« Reply #9 on: October 25, 2007, 09:24:38 AM »
Very valid points DOC, and something I try to keep in mind, put in the whole equation as every peice does make a difference, I neglected to input my altitude in my post, typically I fly at 2500 feet at home, and then contests are mostly at 100 to 300 feet ASL
« Reply #10 on: October 26, 2007, 06:17:59 PM »
To be quite honest, I have not seen a LA 40 run as good as the LA46.  The .46 is lighter, uses minimally more fuel, but does need .018 lines.  That's less of a problem that most people let on.  For me, I agree with Ty: dump the LA 40 and use the LA46.
The Brodak 40 is a very good "stunt 40" in the old fashioned way.  It's definitely NOT a PA or RoJett 40 (or even an Aero Tiger 36) but still a good "40".
« Reply #11 on: October 26, 2007, 06:28:46 PM »
I wish you guys would stop bad-mouthing the LA 40 long enough for the demand to go up so I could sell mine and recover my investment.  I bought mine when people were raving about how good they are.  ::)
« Reply #12 on: October 26, 2007, 07:20:09 PM »
I've flown or pitted all of those.
A guy we fly with every week has a plane with an LA46.  It just about drags me across the field trying to hold it back.  The others don't.
« Reply #13 on: October 26, 2007, 09:54:45 PM »
Hi Jim,
Forgot to mention that I suggested to Dee the 12.25X 3.75 APC as a starting point and that he use the LA 46 instead of a LA 40.  I think he likes the combo.
Of course the APC was just suggested as a starting point, but it does work well.  Sometimes so well that you just don't bother to change it. ;D
Offline Bradley Walker
    • The Urban Rifleman
« Reply #14 on: October 27, 2007, 05:13:28 PM »
I run the same prop on the Brodak 40.
-George Bernard Shaw
« Reply #15 on: October 28, 2007, 02:47:10 PM »
Andrew, I want them to bad mouth the LA 40 more or even the Brodak 40 so I can get them cheaper on the bay.  Was getting Fox 35 Stunts for less than 30 until people started leaking out on how to make them run.  Have fun,  DOC Holliday
« Reply #16 on: October 29, 2007, 12:41:15 PM »
Sorry, Doc, can't bad mouth the Brodak 40......................... ;D
« Reply #17 on: October 29, 2007, 07:28:58 PM »
I'd ask you guys to send your crappy LA 40's my way, but I bought seven a few years ago for a good price.  None of the first three have shown any signs of wearing out or running poorly, so I still have plenty.  The 46 is a bit more plug 'n play, but the 40 will run just fine with the proper venturi/prop/fuel and either a bit of grinding on the head or a few extra gaskets.
Offline Geoff Goodworth
« Reply #18 on: October 30, 2007, 04:52:31 AM »
Mercenary, Doc, mercenary!   n1   n1
Cheers, Geoff
steven yampolsky
« Reply #19 on: October 30, 2007, 04:48:05 PM »
My experience with these engines is as follows:
B40: I've flown 3 different ones. All where 3-rd production run or later versions. All were bulletproof and plenty powerfull. If you are looking for a classic big 4-2-4 run, bolt on a 10X6 prop, run it slow and it will lurch in a classic 4-2-4 fashion. I prefer very little break and settled on Thunder Tiger 11.5x4 prop and run it in quick fast 4. When it breaks, I don't get that "lurching" effect of a 6" pitch prop.
LA40: never owned one or seen on run so can't comment
LA46: Flown two different ones. One worked very well in a narrow operating range. The other did not work no matter what prop, fuel, muffler, ventury or shims I put on it.
Ultimately, I prefer B40 over any one of those motor just because it has such a wide operating range.
Offline Steve Scott
« Reply #20 on: October 31, 2007, 06:06:16 PM »
I have the B-40, LA-40 and LA-46.  Not flown the LA-40 yet but the LA-46 is set up on the ARF Tutor.  Using the MACs stinger muffler and APC 12.25-3.75 cut down to 11.75.  It just purrs right along.
B-40 is being flown in my son's ARF Primary Force with an APC 10.5-4.5.  We were using a 10-4 but haven't enough flights on the former prop to adequately compare.
All fuel is Sig Champion 10/20 with added castor.
Offline Robert W
« Reply #21 on: November 01, 2007, 06:22:09 AM »
I have run 2 LA46s, one in a vector and one in a Cardinal, both models were around 42 ounces. Both combinations run very good in a steady 2 mode with 11.5 X 4 zinger prop. I have tried other setups but for my models this seemed to work best.
I have been running a B40 in an ARF Nobler ( 43 ounces) for a few years and set it up for a 4-2-4 run. In the beginning the motor was a little touchy, but now it is very consistent. I like the run it is giving and bought two more for future classic projects. I did put an LA46 into the Nobler for a couple of flights but did not like the combination and switched back to the B40. The main reason for switching back was I did not want to take the time to re-trim the model for the different motor.
Both are very good and usefull, but the selection should be based on the type of run you are happy with.
Robert
AMA 28627
steven yampolsky
« Reply #22 on: November 02, 2007, 01:14:00 PM »
Speaking of weights,
B40 pulls my 49oz Chipmunk easily, even in windy weather. When Windy Urtnowski flew it, his comment was: "I can win contests with this model!". A year after he flew it and many other models later, he still remembers how well the model flew and how EXCELLENT the motor run was.
Offline don Burke
« Reply #23 on: November 02, 2007, 03:14:22 PM »
Doc,
"....I have removed the blue coating that was on it."
 Just a note.  I crashed a 25LA Blue recently and destroyed the crankcase.  On taking it apart to get the usable parts in noticed inside the bypass passages several casting voids.  They were apparently sealed with the "blue coating".  It's possible the coating process was developed to make up for problems with the casting process.  Taking the coating off, either blue or natural has the possibility of creating a "leaker"!
don Burke AMA 843
Menifee, CA
Offline Jim Oliver
« Reply #24 on: November 02, 2007, 04:09:25 PM »
As has been observed, by some with much more experience than I, no body is making money "fixing" Brodak 40's.
They come already "fixed".
Jim
Jim Oliver
AMA 18475
Online Steve Helmick
« Reply #25 on: November 04, 2007, 10:13:18 PM »
The only "fix" that B.40's need is a smaller venturi. The ones we got had around .306" venturi bore, which would give a harsh break. Putting several layers of pantyhose mesh over the venturi would be an easy and cheap fix. Or a Bruline Fine air filter, your choice.  D>K Steve
Offline Jim Oliver
« Reply #26 on: November 05, 2007, 05:20:13 PM »
I have been using a layer of the more open part of the panty hose material---mostly to keep trash out.  I may try another layer or two in an attempt to adjust the run.
Jim
Jim Oliver
AMA 18475
