Greetings guys from a mild and sunny Charente in S.W.France.
Went to the field yesterday , late afternoon, no wind ....paradise. Took my ' mod'd Twister ' which has an OS35 FP beautifully modified by Tom Dixon. I was using a plastic tank , plumbed for uniflow and fuel with 24% lube' and my usual flying prop' , a Master 10x6.
The FP started as usual , and settled down to it's normal flying setting.
So , first flight , all just fine as usual. Came down without a hitch [ which is a big bonus for me ! ] and let her cool off while my pal and I sorted out the world's financial crisis !
Next run ....Odd ... started her up 2nd or 3rd flick [ all Tom's engines start on the button ] but I had to wind the needle in almost half a turn to get the same revs on the tach' , just on the 4/2 break.
Now I'm a re-tread , only coming back to C/L Stunt a few years back after a long working 'sabbatical' so I would appreciate any of your views.
Probably I'm missing the blatantly obvious , so if I am ....apologies.
Once again , thanks and a great forum fellas.
Kind regards from an ex-pat retired Brit in the Charente - full of ex-pat retired Brits !
Robin.
