  • June 22, 2025, 09:15:45 PM
Author Topic: I have an OS 45 F  (Read 1082 times)
Offline sleepy gomez
I have an OS 45 F
« on: June 24, 2009, 02:36:12 PM »
I have an OS 45 F.  It was an older RC engine.  I plan to use it on a 55 ounce plane.  I'm not looking for a 2-4-2 type of break.  Any suggestions on a prop would be welcome.
Re: I have an OS 45 F
« Reply #1 on: June 24, 2009, 10:49:30 PM »
Has anyone ever heard of one of these?
Offline dennis lipsett
« Reply #2 on: June 25, 2009, 05:19:33 AM »
You might be talking about the OS 45 FSR. A really nice engine from the 70's and that series was in my opinion the zenith of OS engine technology. I have a 45 and just rebuilt it with a Bowman ring. Very good runner. Now for the bad news. I can't help you with any info for it's use in C/L. It was never converted over.I ran 11/5 on it R/C. You probably could go up to a 12C/L depending on the aircraft.
Interesting tidbit, the 45 cost $20.00 more at the time of it's introduction over the 40. A lot more 40's were sold then the 45. Guess $20.00 was at the time a deal breaker
« Reply #3 on: June 25, 2009, 10:01:33 AM »
Thanks Dennis.  This may be the engine you describe.  On the side it is only stamped  45 F.  Otherwise it is as described.  I'll make a venturi.  I have a new ring for it.  Thanks again.  SLEEPY
« Reply #4 on: June 25, 2009, 10:05:38 AM »
Hi
If it is a 45 FSR  try a 270 restrictor witha .157 spray bar thru it, use a 12 x 4.5 prop. make sure it has a good ring fit and good bearing. If it is setup Ok it will run a nice hi RPM 4-2
