  • June 23, 2025, 08:37:26 AM
Author Topic: evo 36  (Read 711 times)
Offline Bootlegger
evo 36
« on: June 22, 2009, 01:16:26 PM »
  You fellow's that are using the evo 36 what size venturi are you using ? I am looking at 10% n 22% oil half & half, want to be able to fly on 4 oz with T/bolt r/c w/idlebar 10 1/2 x 4 1/2 apc prop at approx 11,000 rpm.
  Jim Lee made me a venturi w/spray bar thru and .295 (Thanks Jim) but it is too big, thinking about ,272 or there about...   Suggestions???             #^
8th Air Force Veteran
Gil Causey
AMA# 6964
Dave Adamisin
Re: evo 36
« Reply #1 on: June 22, 2009, 09:43:14 PM »
Hi Gil. Are you using muffler pressure? The .295 vent with a .155 dia spraybar would allow for a lot of power but probably not without MP. The largest vent that comes with the engine (the shorty) is about .277 id. You can drill it through and put the valve through and come pretty close. I've been playing around with the fuel consumption issue and found that making an insert with a sharp edged hole on the bottom has a fair sized effect on improving the fuel consumption. If I were having someone make one for me I would go with the .272 with the sharp hole. You can always make it bigger.
« Last Edit: June 23, 2009, 11:45:44 AM by Dave Adamisin »
