  • July 16, 2025, 09:03:57 AM
Author Topic: What is the easiest way to start PA 40  (Read 1286 times)
Offline Brian Thwaites
  • ACE
« on: September 28, 2006, 01:07:07 PM »
Probably Randy can answer this. My PA 40 starts one flick if upright but is a pain to start inverted any suggestions from anyone would be appreciated.
Thanks in advance
Brian
Brian Thwaites
Re: What is the easiest way to start PA 40
« Reply #1 on: September 28, 2006, 07:14:26 PM »
Thanks in advance
Brian
If it is piped, always flip it over and "burp" it the first time each day.  That clears it out.
Other wise two or three chokes, a couple flips, and snap back on the spinner.  Everytime starts.  It gets even easier after it has been run a couple hours.
You are probably flooding it inverted.  It doesn't take much to prime, and after a few flights on a warm day, we do not even choke them, just a couple flips before hooking up the battery.
Bill <><
Offline Manuel Cortes
« Reply #2 on: September 29, 2006, 05:29:18 AM »
Mine is exactly like Bill says.
I bought it 7 years ago to Antonio Mira (passed away last year) and I was told it had new bearings and P-S assembly. It´s still running strong in my 59 Oz SV12.
It´s marked Randy 20 by hand in the case.
Great engine!!!
