  • July 11, 2025, 08:33:43 PM
Author Topic: Chinese S/T 51 Ring Setup  (Read 1748 times)
Offline David L Trotter
« on: October 23, 2007, 07:19:51 PM »
Have a Chinese S/T C/L .51 (new) that I would like to remove the ring, check the gap (& fix if needed) and reinstall, perhaps without destroying the ring. Then proceed to break it in.
So, couple of questions......
1) Procedure for removing it and replacing it?
2) Proper gap for the original ring, and best method for increasing gap if required?
Cheers,
David
Offline dennis lipsett
Re: Chinese S/T 51 Ring Setup
« Reply #1 on: October 23, 2007, 09:39:54 PM »
There is a fundamental rule that I follow and that is 'don't fix it if it ain't broke' I have a China  ST51R/C that I have run for well over a year on Powermaster 10/18 and it is still a one or 2 flip starter and has an excellent top end and idle. Just clean the motor well before you run it the first time, take your time breaking in and then go fly. They are not a typical Chinese motor. Taking a ring off and on is just not one of the things that should be done just because.
dennis
« Reply #2 on: October 25, 2007, 09:28:41 PM »
Dennis has it right. The #1 rule for piston rings is to replace them if you have to remove them from the piston. If you decide you need to, get a Frank Bowman ring (or two), or just send the P&L to him to fit the ring. Or Tom Lay. He's busy, but he is shipping engines. My G.51 and .46 came in today's mail. ;D ;D ;D y1  Steve
Offline Jim Oliver
« Reply #3 on: October 25, 2007, 09:33:57 PM »
Goody---maybe I will get my 51 back soon!! #^ #^
Jim
Jim Oliver
AMA 18475
« Reply #4 on: October 26, 2007, 06:23:03 PM »
Randy has a neat suggestion for a simple check on the ring gap....which is to move the piston and ring so that gap can be seen and estimated through the port.  If a sheet of paper (assume 20#) will fit the gap is OK as it represents .002 to .003.  And he indicated the gap has been acceptable on most of the s/t 51's out of the factory.  Says it is the break-in that usually causes the ring problems.
Things leaned...........
David
Offline Dennis Vander Kuur
« Reply #5 on: October 29, 2007, 01:14:00 PM »
David,
Did Randy specify what type of breakin problems he was referring to (i.e. wrong fuel, wrong size prop, wrong rpm, etc.)?
Thanks.
DennisV
Dennis L. Vander Kuur
AMA 29292
Online RandySmith
« Reply #6 on: October 29, 2007, 02:30:57 PM »
David,
Thanks.
DennisV
Hi Dennis
I told him that I have seen many rings ruined by improper breakin, If you get the engine too lean or too hot during it's first few runs the ring will expand too much forcing the ends to touch, at that point the brand new properly gapped ring is toast, it will either break or wear a flat spot on the ring. neither is good.
When you break these in with a tight gap, you need to ALWAY do it on the ground, preferably on a bench so that you can control the breakin process. If you try to fly it and it goes lean all you can do is watch it kill the new ring.
The best way to break in a new  ST 51 is with the engine running very sloppy rich, then lean it out till it runs a very fast 4 cycle, pinch the tubing so that it will just burst into a 2 cycle for a couple of seconds, Do this for the first 3 tanks of fuel. After the 2 cycle go back to a very rich 4 cycle then up into a very fast 4 cycle..repeat process..
I use 4 ounces at a time.  After the first 3 or 4 runs you can put the motor in a 4 fast cycle, then into a 2 cycle for a couple of seconds then back to a nice rich 4 cycle.,
I break these in with SIG Champion with 2 ounces of AERO-1 added to it,and an additional 2 ounces of Castor.
I use Sig fuel to run these by mixing the Champion (half syn half castor 20%) with the 25% all castor SIG, and add 1 ounce of Aero-1,  You can substitute either castor or syn oil for the Aero-1 if wanted. They seem to like to run 24% oil total part castor and  either  5 or 10 nitro. The nitro percent will not matter on breakin
« Reply #7 on: November 02, 2007, 12:12:24 PM »
Greetings Randy,
Many thanks for the information. I know a couple of people who have had problems  ~^ with their new Chinese ST .51 engines (i.e. low compression, broken rings, erratic runs, etc.) so I was interested in any information that would help break in the engines properly.
Best regards,
DennisV
AMA 29292
Online RandySmith
« Reply #8 on: November 02, 2007, 12:47:04 PM »
Greetings Randy,
Best regards,
DennisV
HI Dennis
I have built 100s of the ST 51s for people and have found not really many more problems with the China 51 than I did with the Italian 51s. If you have one that is low on compression, it has a problem no matter which version it is. either a bad ring ,broken ring, or a out of round sleeve, and  needs  attention to correct the problem. I have also had a lot of people ship me their 51s that do not run well , both versions and I have found flat spotted rings and broken rings.
The sleeves for the most parts have had little problems.
Offline Richard Edwards
« Reply #9 on: November 13, 2007, 10:29:39 PM »
Randy,
 I am presuming you are talking about the C/L version of the ST51 as I have noticed the R/C liner is different and even gone as far as buying C/L liners for R/C 51's I was given as gifts by family that didn't know the difference, when I went to reassemble them with the C/L liners the rings broke so I ended up sending them to Frank Bowman for him to put on new rings and reassemble them for me.
