On something like a Fox 35 it's pretty simple. But say you have a ball-bearing engine and all you can see with the back-plate off is the rod sticking out from between the two wristpin supports and there doesn't appear to be any slop in the wristpin. How do you check for a stuck rod without taking everything apart?
