  • July 24, 2025, 11:50:56 PM
Author Topic: Castor Oil  (Read 5163 times)
Offline Chancey Chorney
Castor Oil
« on: August 04, 2016, 07:20:15 PM »
Hi there. So I had finally picked up a gallon of Sig Champion 5%, All Castor Oil for my Fox engine (thank you Dennis for picking this up for me). I am now in need of Castor oil to top the overall oil percentage to 29%. Castor oil is all but non-existent here in Manitoba. Locally, I have exhausted all of my resources in trying to source anything. I called speed and race shops, motorcycle shops trying to find anything. I was asking for anything with pure castor, a Lucas product, or Klotz Benol, as they are the only two I am aware of by name. I did this with zero success at any of the shops. The hobby shops here (been to both) no longer carry Castor oil, only the synthetic blends, nor do they carry Sig fuel either so that is also out of the question. I have done some reading, and I am torn up on what to do next. I do realize that it will not be cheap, BUT, could I get away with pharmaceutical grade castor oil, as it is my last hope (ok, second as I am waiting to hear back from a possible performance shop to get back to me). Darn, $6 CAD for 3.3 oz/100ml. But at the same time, I do not want to ruin my new Fox 35! If anyone here has any other suggestions as to castor oil use that I may try to find locally, it would be greatly appreciated. Thank you.
Offline George Truett
Re: Castor Oil
« Reply #1 on: August 04, 2016, 07:40:58 PM »
I'm pretty sure castor by itself is not Hazmat.  Is ordering from Sig or somewhere like Tower not a possibility?  I see VP Racing fuels has a distributor in Calgary, might be worth a call to see if they can get the Powermaster products.
Offline Brad LaPointe
Re: Castor Oil
« Reply #2 on: August 04, 2016, 08:02:09 PM »
Great Hobbies sells Sig castor . Mail order from them should be easy - no customs . Check under fuel .
Brad
MAAC 5418L
Re: Castor Oil
« Reply #3 on: August 04, 2016, 08:30:36 PM »
Thanks for the Great Hobbies tip. I may have to resort to that if the last e-mail does not work out. Not too bad, $43 shipped per quart to me. I just had another lead of Go-Cart racers. Will check this out next week.
Re: Castor Oil
« Reply #4 on: August 04, 2016, 09:28:37 PM »
I race go-karts (for 45 years).
Do not put go-kart castor in your glow fuel, it's not the same, it's thinned down and usually has additives that will not mix well. You can order the right stuff from S&W Fuels or Sig. Also, do not put Sig castor in your go-Kart.
20% castor is plenty for a Fox 35. We race them 10 minutes at a shot fully leaned out with 20% castor and they live just fine so a 2/4 stunt run is a cake walk.
Re: Castor Oil
« Reply #5 on: August 04, 2016, 11:37:22 PM »
Among MANY hits I get, should be no problem with shipping:
   http://www.countylinehobbies.com/sigaacaoilqt.html
http://www.ebay.com/itm/Klotz-Oil-BC-172-Benol-2-Cycle-Racing-Castor-32oz-/111846004292?hash=item1a0a8a9644:g:6rUAAOSw7FRWaGDu&vxp=mtr
   And to the contrary, you DO want to have much more than 20% oil. It will run on that, but it will run much better on 25% and even better on 29%. Almost better than adding nitro - which I would suggest you also do. 10/29 will really wake the airplane up with little risk of breaking the crank, 15/29, even better with some risk, and anything more, it will run GREAT - until the prop/spinner/end of crankshaft flies off into the weeds.
Re: Castor Oil
« Reply #6 on: August 05, 2016, 05:41:04 AM »
Well I am waiting for another reply from the local supplier I had emailed yesterday.  He is going to see what he can do. Anxiously waiting.
Offline Steve Hines
Re: Castor Oil
« Reply #7 on: August 05, 2016, 08:35:37 PM »
Call or text Rich's Brew, he has castor for sale if you ask. It is what I been using for two years. Good stuff at a good price.
Re: Castor Oil
« Reply #8 on: August 05, 2016, 10:15:42 PM »
McMaster-Carr has castor oil.  It works fine.  I don't know if they ship to the Frozen North.
Re: Castor Oil
« Reply #9 on: August 07, 2016, 02:25:00 PM »
Well, I had heard back from the company. He is able to get me the Klotz BeNOL delivered to my city at a very reasonable price. So, I was just wondering if anyone has anything bad to say about this, but it is the best and cheapest I can get. Thank you again for your help and time.
Re: Castor Oil
« Reply #10 on: August 07, 2016, 05:03:27 PM »
The castor oil in Klotz benol is a thinned down version of castor oil. Bigger engines run hotter than model engines. If you put our pure modeling castor in a big engine it will coke up badly in a very short time which is why they thin it down. Also, Klotz benol has synthetic oil and other additives in it that may or may not mix well with glow fuel. Do not put go-kart/motorcycle oil in your glow fuel.
5% nitro 20% castor will be just fine for your Fox.
Re: Castor Oil
« Reply #11 on: August 07, 2016, 05:19:14 PM »
  20% is not nearly enough oil. Many of us have many thousands of Fox flights, it is not a mystery or experiment.  It might last acceptably well on 20% oil as long as you never ever get a lean run, but it will run vastly better on 25% and even better on 29$, and will almost always pick up power and do the 4-2 transition much faster. On 20% oil it is very lazy about switching, particularly, it will hang in the 2 much longer (or forever).  That effect will be even more evident on 5% nitro, too.
    This is a long-solved problem. It is debatable whether it has to be all-castor or not, but use at least 25% oil and preferably more in a Fox in stunt.
Online RandySmith
Re: Castor Oil
« Reply #12 on: August 07, 2016, 05:37:48 PM »
If your  Foxes  are new or at least not full of burned on castor, you will be well served to use 28% oil in your fuel with 1/2 or 3/4 %  castor and  25 or 50% synthetic oil mix, they will work better and  last longer.
DO NOT  use  20%  oil, you will  kill the top of the rod, and put wear on the  engine much faster, plus it will  NOT  run as well.
I would check your Sig fuel.  they make all castor 20 and 25%  oil
Re: Castor Oil
« Reply #13 on: August 07, 2016, 05:45:05 PM »
Engine in question is a new, unrun Fox .35 50th Anniversary Edition, as well, my Sig fuel is 5% nitro 25% all castor oil. Thank you.
Re: Castor Oil
« Reply #14 on: August 08, 2016, 12:00:56 AM »
This is the Benol you could get from Tower Hobbies. http://www3.towerhobbies.com/cgi-bin/wti0001p?&P=SM&I=LXS627  I don't know if there are other "Benol" products from Klotz, but you can always check the Klotz website.
This "Tech Info" will tell you what you can mix with it: http://www3.towerhobbies.com/cgi-bin/wti0001p?&P=SM&I=LXS627#tech
However, since you have 25% castor to work with, I'd be thinking about adding enough "Klotz Super Techniplate" (which is itself 20% castor) to bring it up to 29% or 30% oil for your bench running, and potentially for further running. For future fuel, I'd try to get 10% nitro x 25% castor and again, add some Super Techniplate.
You can also get "Aero-1" lube additive from Randy Smith. I've used it quite a bit, typically in Wildcat Premium 10-18 R/C fuel, which has some castor oil in it...and is used in my ABC or AAC engines. I'd use it for break-in in any engine, especially a Fox .35.
I know George Aldrich used a test prop that was an 8x5, cut down from (IIRC) an 11" wood. Run it very rich to keep the rpm down to start with. Check Randy's pinned articles at the top of this forum for more info. I'd plan on using a 4-cycle/Big Bore Thunderbolt glowplug. You might need to keep the battery on for awhile...ideal place for a power panel/glow driver combo driven off a 12volt gel cell, if you've got one. When you have most of the gallon of fuel through it, it might be ready to fly, if you're careful to run it quite rich and run a 10-5 prop at most.   H^^ Steve
Re: Castor Oil
« Reply #15 on: August 10, 2016, 09:30:17 PM »
Sorry for taking so long to update this. But just before I was to place the order, someone local to me has offered up a gallon of Bakers AA castor oil. I will however have to wait and be patient, but I will at least get the good stuff. I have a bunch of other stuff to do in the meantime anyways.
