  • July 30, 2025, 09:24:21 PM
Author Topic: Carbon Fiber RE header muffler  (Read 10357 times)
Walter Hicks
« on: February 12, 2006, 10:53:01 PM »
I noticed a picture of a Skywriter with a PA or RO Jett Re and a short header pipe with a Carbon Fiber Re muffler ataced to the header via silicone seal similar to a tuned pipe.
I have PA .65 RE ,(what an engine) with a cut down header pipe and
a CVEC dual exhaust muffler(used on RC race cars). It is very quiet
similar to a tuned pipe sound. It appears to have lots of volume
1.5 dia and 4.78 long.Today was the ist attempt to use it in a plane.
It seems like and others who observed agreed that I will have to increase the inside diameter of the two exhaust tubes in order to make this work? If it is possible could Randy comment on the C/F Re muffler (
(looks like a tuned pipe except very short like a muffler), and what he might think I would have to do (exhaust tube inner dia to get the CVEC
muffler to work? Thank You very much.I gutted the inside of the CVEC
muffler.
Re: Carbon Fiber RE header muffler
« Reply #1 on: February 13, 2006, 11:14:52 AM »
HI Walter
What you saw was a Merlin series PA 40 ultralite with one of our CF slide on mufflers. We also have the same muffler in Aluminium.
I would need to see the muffler you are talking about to give exact details, however I can say with an almost certainty that you would need to open up that muffler as much as possible for use with The 65. and  you will need to  run a  larger venturi.
The mufflers as opposed to pipes, seem to alway have the motor acting like the venturi is much smaller. So if you run the exact motor on a pipe then a muffler, the motor wants about 2 or 3 steps larger on the venturi size.
Try to open the venturi 2 number drill sizes larger (example #12 to #10) and make sure the muffler is opened up as much as you can
Please let me know how this is going either  here or  at my email
randyaero@msn.com
Walter Hicks
« Reply #2 on: February 13, 2006, 08:48:59 PM »
WOW!
  Thank you very much Randy for the information I really appreciate it.
Check you  email re C/f muffler.
Question #3- Can you drill the PA venturi to a larger dia or does this
mess up the venturi? Otherwise if I want a larger venturi do I have to
purchase a larger one or can I do the usual drill it myself? Thanks
« Reply #3 on: February 13, 2006, 09:36:15 PM »
Hello Walter
The best way is to send it back to me and i can open them up and recut the proper angles in them. I do not charge for this service, only thing you will pay is shipping.
To answer your question more direct, you can normally get by with 1 drill size bigger, but the larger you drill a true venturi, the more you make it a tube, and it is not as effective.
