  • June 22, 2025, 04:05:48 AM
Author Topic: McCoy .35 RH wrist pin end pads available?  (Read 2018 times)
Offline Terry Caron
« on: February 10, 2015, 07:12:15 PM »
Hi all -
My latest E**y treasure is a nice '57 McCoy .35 RH (no venturi bosses).
It needs a pair of brass wrist pin end pads - is there a source for them?
Anyone have a spare pair in your parts bin?
Thanks.
Terry
« Last Edit: February 10, 2015, 10:18:24 PM by Terry Caron »
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Re: McCoy .35 RH wrist pin end pads available?
« Reply #1 on: February 11, 2015, 11:51:01 AM »
Hi all -
Thanks.
Terry
Hi Terry,
Contact Jim Lee at Lee's Machine Shop in the vendors corner.  I have never seen these offered separate.
Offline Terry Caron
« Reply #2 on: February 11, 2015, 01:12:05 PM »
Hi Terry,
Thanks Bill -
I've contacted him - fingers crossed!  ;D
AMA 249824
NRA Life Member
Offline Larry Borden
« Reply #3 on: February 17, 2015, 09:21:13 AM »
Someone on ebay offers a gasket set that includes the pin.
Offline Terry Caron
« Reply #4 on: February 21, 2015, 11:25:57 AM »
That set has the pin for the crankshaft throw but not for the wrist pin.
Jim Lee also has that pin but nothing for the wrist pin ends.
I know there are those who like/rebuild/restore McCoys, and it seems this would be a common wear prob for them.
Since the brass wears away, the pin ends must eventually damage the cylinder - how is this normally addressed?
Terry
AMA 249824
NRA Life Member
« Reply #5 on: February 21, 2015, 01:09:02 PM »
Hi Terrry; Some of the later Red Heads have teflon wristpin pads unlike the older ones that used what looks like a brass eyelet. I will do some checking and see if I can help you out.
« Reply #6 on: February 21, 2015, 02:27:13 PM »
Terry
Hi Terry,
Back in the day, the engine was wore out by the time the pads were. Had to get a new engine.
« Reply #7 on: February 21, 2015, 02:28:08 PM »
Hey Terry. I don't think the brass pads will come out without drilling them out. I tried to pull them out and they won't budge. I can send you a complete wristpin if you will send me your old one so that I can drill them out and make new pads. If that will work for you send me a pm with your addresss and I will get it in the mail to you tomorrow.
Offline Terry Caron
« Reply #8 on: February 21, 2015, 05:13:27 PM »
PM sent Jim - and a huge THANK YOU!!  :D
Terry
AMA 249824
NRA Life Member
