Hi All:
I have been having problems with the tank set up on my Fox.25 profile stunt trainer.
The problem is that after I set the engine to run a great 4 cycle on the ground it leans out to a screaming 2 cycle in the air that results in a very hot run. The engine is fried when it finally lands! Thanks to a large proportion of Castor Oil in my fuel , the circa 1953 Fox still has a bit of compression.
The tank is 2.5" long,1.5" tall and 2.375 widr. The distance to the fuel pickup crease in the tank is 2" from the nva. Is this too far to draw fuel? There are no leaks in the system or fuel foaming as far as I know. Is this tank, four oz.. too large for this application?
I need to ask about the profile tanks that Veco and Duke Fox sold at one time. These tanks were designed to used on profile planes but I have been told that they will not work! They look good but what do I know? The Veco box call it a T series tank. Pehaps I should convert these tanks to a Uniflwow system to see if they work. Any thoughts about these tanks?
I am having the same problems with a Midwest Me 109 profile stunter with a 5 ounce wedge tank and an O.S. .35 Stunt. I converted the tank to uniflow but that seemed to make the problem worse. Any thoughts about this prblem?
Perhaps it is past time for me get new tanks! Lol Hello Brodak!!
Thanks for any input that you may have concerning my tank problems.
Stay well,
Frank
Ps.
This tank on the Fox .25 worked very well on a slow combat plane in the 80's. It is a suction tank.
