  • June 20, 2025, 10:34:57 AM
Author Topic: Fuel storage...  (Read 1678 times)
Fuel storage...
« on: November 03, 2006, 08:04:43 AM »
 With winter coming soon in these parts I was wondering, is it a big deal if your sealed fuel sits where it gets below freezing (in the garage), or should it be stored indoors?
Offline Ralph Wenzel (d)
Re: Fuel storage...
« Reply #1 on: November 03, 2006, 09:57:14 AM »
FWIW, I keep everything inside; fuel, dope, kits, planes. It's always between humid and wet in the Houston area; really warm in the Summer and quite cool in Fall/Winter (sometimes really "windy", too). If our garage were insulated and temp-controlled, that would be preferable, but it isn't.
Yes, I know our insurance agent would have kittens if he knew of all the stuff I store inside.
Ralph Wenzel
AMA 495785 League City, TX
Re: Fuel storage...
« Reply #2 on: November 03, 2006, 11:02:06 AM »
It shouldn't hurt the fuel to get below freezing in the winter.  Just make sure you warm it up with the lid on(to keep out moisture) and make sure it is thoroughly mixed before using it.  Theoretically, the cold could cause some of the oil(castor esp.) to separate out.  It will redissolve at more normal temps.
Re: Fuel storage...
« Reply #3 on: November 03, 2006, 11:04:23 AM »
That's pretty much what I figured.
Thanks!
Offline Mike Spiess
  • bikemike
  • AMA #4060
Re: Fuel storage...
« Reply #4 on: November 03, 2006, 11:07:28 AM »
Hey Wayne I have keeped diesel fuel fresh over the winter. How I do it is I put it in metal containers with good sealing caps and store it in the basement as the temp is more consistant. In the garage or storage shed the temp viares allot thru the winter. As for glow fuel I keep it in a cool corner in the original containers.Just make sure the caps are tight. If you notice the jugs deforming then the temp isn't constant enough. Then just buy new fuel in the spring. n~
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
Offline Mike Spiess
  • bikemike
  • AMA #4060
Re: Fuel storage...
« Reply #5 on: November 03, 2006, 11:11:21 AM »
The freezing won't hurt the fuel it's the temp changes that is a culprit. Here in MINN it can varies as much as 120-130 deg from real cold to real warm. And as you know it can happen in the same month.
if there's ice forming throw it out as there is water in it.
St Peter MN
Re: Fuel storage...
« Reply #6 on: November 03, 2006, 12:33:41 PM »
I used my old fuel as weed killer a couple of weeks ago. I have one jug that should take me through the winter. I'll buy fresh in the spring.
Offline Richard Grogan
Re: Fuel storage...
« Reply #7 on: November 03, 2006, 01:49:44 PM »
Your garage wouldn't be big enough anyway! f~    ~>
Long Live the CL Crowd!
                  AMA 85745
