  • July 17, 2025, 11:02:13 PM
Author Topic: Bum auction engine  (Read 2034 times)
Offline RDJeff
Bum auction engine
« on: November 16, 2011, 09:52:22 AM »
Hey gang.  I bought an FP35 on the auction site, it looked okay in the pictures, had some oil stains onit, but otherwise fine.  It showed up yesterday, and I opened the box in the post office parking lot.  This thing has never been mounted, and is all nice and clean, the piston looks new, it's a bit stiff turning, though the throttle lever is stuck.  Anyway, I sent good feedback to the seller.  When I got home last night, I started playing with it, and noticed slop at TDC, hmm, not good.  Then I noticed the crank is bent. ''  So I pulled the backplate, and what do I find, but a crank that is all gunked up with years of burned on oil, and evidence of moisture damage.  It appears that someone stuck an old, bent crank in a previously un-used engine. R%%%%
I got this engine cheap enough that if I can get a new crank, it's probably worth it to hang onto it instead of hassling with returning it.  Are parts readily available for the FP35?
Thank in advance!
Jeff
Offline Curtis Shipp
  • AMA 753063 / Advanced Stunt Flyer Finally
Re: Bum auction engine
« Reply #1 on: November 16, 2011, 12:25:50 PM »
FP and LA cranks are the same basic size and stroke in 35, 40 and 46. Some are machined and some are forged but otherwise the same. Rods also but pistons change to get more cubic inches.
Yes parts are available. You may have to look around though.
Life is to short to be sour.
Offline RDJeff
« Reply #2 on: November 16, 2011, 02:17:42 PM »
Thanks Curtis,
I found the information on the O.S. site, and see that the crank is available from Tower, so I should be good to go.
« Reply #3 on: November 16, 2011, 08:34:09 PM »
If someone had an unused FP, what would make them take out the crank and replace it with rusty bent one? Makes no sense. ???
Offline RDJeff
« Reply #4 on: November 17, 2011, 09:48:29 AM »
Yeah, it didn't make sense to me either!  I tore the engine down last night and found that all the pieces are original, and it's never been run.  The gunk I saw in the case was just a lot of rust and old oil.  Other than being bent, the crank is perfect.  the rod has some staining on it, but the bushings are fine.  The only other piece that needs replacing is the wrist pin, which had some nasty grooves corroded into it.
Offline RDJeff
« Reply #5 on: November 17, 2011, 05:23:48 PM »
Thanks for the sage advice Ty!
I live in Alaska, and don't know of any other C/L fliers in the area, and it might be some time before I get to fly with any of the family on here.  So, in the meantime, I'll just do my best to fit in with the family and not get too annoying.
I flew a lot of 1/2A stuff when I was a kid, then moved up to Fox .35 powered stuff, then quit flying for 35 years or so, and am just getting back into it.  The information on here is invaluable, so thanks to everyone in the family! H^^
Offline Dennis Moritz
« Reply #6 on: November 17, 2011, 10:28:19 PM »
I've bought lots of engines on ebay and other sites and at swaps. All in all I've come out ahead. Probably way ahead. That's a judgment call, strictly, nothing scientific. Weird stuff is going to happen. Part of the experience. I've bought engines of pristine appearance, clean as a whistle, not a mark on them anywhere. Bad compression. Poor runner. As tho someone had mismatched a piston and liner. On the other hand I've a $20 LA46 with grooves cut 90 degrees to the mounting holes. Fantastic compression. Runs like a bear. Some folks are skilled in the voodoo arts. Crock potting, washing engines in a dishwasher, who know what the mind of man... At a swap watch out for the three in one oil smell. Check out the rep of the seller. Give him or her the fish eye. Naw. None of that works. Buying on Net or at swaps is a recreational activity. Ultimately. Even the smart old heads get taken now and then. Recently I've come around to buying engines new from reputable dealers. Why. Why. Must be old age. Also, I'm getting a hair more serious about competition. My sorry level of competition, that is...
The LA 46 CL engine new in a box from Tower or another reputable dealer is, all in all, a very reasonable purchase. Definitely stunt friendly. Will fly any plane an FP40/35 will fly. Weight about the same. It's a direct bolt in. Even the exhaust is in the same place. Head shape is somewhat different. That's it.
« Reply #7 on: November 17, 2011, 10:48:20 PM »
PM me. I'll send you a straight crank. Free.
Offline MikeMorgan
« Reply #8 on: November 18, 2011, 07:19:22 AM »
Famous Ebay engine description......"super strong compression with buttery smooth bearings"............ha, anything packed with marine grease feels good.............eBay is such a crap shoot, you just never know.
looks like you got a crank for it though........ #^
-mike
Team Satellite
ama 70865
Offline Marvin Denny
« Reply #9 on: November 18, 2011, 08:16:54 AM »
  I have bought nearly 200 items off the bay, and have never gotten stung.  But dealing with people on the forums I really got taken one time.  Not bad for all the various dealings.
  I'm happy.
    Bigiron
marvin Denny  AMA  499
Offline RDJeff
« Reply #10 on: November 18, 2011, 09:41:59 AM »
This one was a total crap shoot.  The description just said "don't know much about it, what you see is what you get".  It actually looked much better in hand than the pictures indicated.
Offline don Burke
« Reply #11 on: November 18, 2011, 12:16:15 PM »
I've only gotten one bad one from ebay.  It was advertised as "strong runner".  After receiving it the exhaust config looked odd, so I took the head off and checked, the liner was in backwards, would "run" very poorly that way.  Corrected that, it runs no problem.
don Burke AMA 843
Menifee, CA
« Reply #12 on: November 18, 2011, 07:20:57 PM »
One problem is that engines may be damaged, even if they have never been run. Poor storage can lead to corrosion, not visible until an engine is disassembled. Bad compression, for instance, especially in a steel liner/cast iron piston engine, can be caused by this corrosion. Some engines I have purchased seem to have been effected that way. Corrosion of the crank can effects bushings, ball or roller bearings, do not fair well at all, if an engine is improperly cleaned and inadequately oiled. AAC, ABC, ABN engines can be damaged by turning the engine, if it is not oiled, or lubed with fuel, or if it is flipped over cold especially when new. A common issue. Since the pinch of a well fitted P/L can create excessive friction when cold. If the pinch is worn away by cold flipping, or even turning the crank over when cold, the engine performance is likely to suffer. These engines need to be run at operating temperature for break-in. Also the excessive friction of cold flipping etc. a new engine can damage connecting rod bearings. More than one engine I've purchased had the tell tale click as the piston neared top dead center. Indicating connecting rod bearing play. A few of these engines appeared to have never been run. I suspect a previous owner did not understand the potential problems of cold flipping a new engine.
Recently I've purchased more than a few engines that in one way or another did not measure up to the advertising statement. Are they usable engines. Most are. But their performance has been compromised. Which is why, when looking for an engine to power a competition plane, I've come to the conclusion that new is best.
« Last Edit: November 19, 2011, 04:42:33 AM by Dennis Moritz »
« Reply #13 on: December 04, 2011, 03:55:20 PM »
One of my thoughts before buying an engine on line is to consider the price and also the costs of some major replacement parts.
Like a ST .46.  I expect to have to buy a ring and bearings.  Maybe a sleeve/piston for a non ringed engine.
That makes it easier to buy used engines, or at least it gives me an idea of what to pay.
I recently got a ST .60 lite case (the good stunt one) for $20.  I DID have to buy a ring and bearings, but that still kept the cost below what most people get for a lite case ST .60.
Big Bear
