  • July 14, 2025, 01:27:23 PM
Author Topic: Broken head fin  (Read 2241 times)
Offline Leester
Broken head fin
« on: January 06, 2015, 10:59:58 AM »
While I was replacing the factory Cylinder head screws with socket head screws I broke off one of the small fins. Am I waisting my time to try and JB weld it back in place ??
Leester
ama 830538
Re: Broken head fin
« Reply #1 on: January 06, 2015, 11:11:29 AM »
  Probably. It's not likely to make any difference in the way it runs, if that is the question.
   I am not sure why you want to replace the screws. if it's a problem with stripping them out, I would replace the screwdriver instead. With the right Japanese screwdriver it fits more securely than a hex driver.
Re: Broken head fin
« Reply #2 on: January 06, 2015, 11:29:34 AM »
I change out my muffler bolts to socket head because I find access easier, but given how seldom I mess with head bolts I leave them alone.
Brett's right about using the proper screwdriver -- if you use the right driver on a cross-head screw it works like a dream.  Unfortunately, there are approximately one bazillion different cross-head screw "standards", so getting one that fits can be a challenge.
Offline Leester
Re: Broken head fin
« Reply #3 on: January 06, 2015, 11:48:02 AM »
I've had trouble with the phillips type screw and have never had the Proper screw driver. There's always been one screw that causes a problem, I had a socket head set so I used them on the back plate and head. We just got 6" of snow so maybe I'll try and JB weld that fin piece back on and pass the time by watching the glue dry !!!  LL~ . .tough being retired,, y1.  Thanks for the reply's
Leester
ama 830538
Re: Broken head fin
« Reply #4 on: January 06, 2015, 12:08:16 PM »
In my humble opinion, trying to glue the fin back on is just about pointless.  It won't stay on, and you don't need it, so why bother?
I do think that you should check the fit of the screws.  If you broke the head fin installing the new screws, then chances are that the reason it happened is because the heads of the new screws are a bit big, and are not seating on the flat part of the pocket in the head.  If this is the case, then you need to grind the seating surface of the screws down a bit to match -- otherwise it'll just be perpetually loose screws, more broken fins, and possibly a warped head.
Re: Broken head fin
« Reply #5 on: January 06, 2015, 12:21:05 PM »
I would JB weld it back on. You don't have anything to loose by trying. Just do not clean the head in a crockpot as it will eat the JB weld and the fin may fall off. Just clean it good with lacquer thinner and glue it on.
Offline John Kelly
Re: Broken head fin
« Reply #6 on: January 06, 2015, 12:48:54 PM »
...Hey Leester, See Dennis Toth's "Socket head bolts US engines" (Nov.23rd) in "Engine set up tips".  Cheers,  John
AMA 11416
Offline Leester
Re: Broken head fin
« Reply #7 on: January 06, 2015, 01:40:21 PM »
Tim, I broke the fin taking the old screws out, the screw driver was angled just a hair and caught the fin. Operator error HB~>
John I'll check it out.
Leester
ama 830538
Offline Leester
Re: Broken head fin
« Reply #8 on: January 06, 2015, 01:45:37 PM »
BTW I used OS socket Head screws #23313000 for the 35/40 FP
Leester
ama 830538
Offline GregArdill
Re: Broken head fin
« Reply #9 on: January 15, 2015, 04:29:20 AM »
Hi Leester,
How much extra cooling do you think you'd get by gluing the fin back on? It's probably only about 1/4" X 1/16", and I suspect that the JB is going to insulate the part denying any extra cooling anyway.
If you're doing it for aesthetic reasons, I can't see a gob of JB improving the looks.
Greg
Offline Leester
Re: Broken head fin
« Reply #10 on: January 15, 2015, 07:55:29 AM »
Greg, Yes I did it for aesthetic reasons, and I don't see a gob of JB. Will it hold ??? I tried !!
Leester
ama 830538
Offline GregArdill
Re: Broken head fin
« Reply #11 on: January 15, 2015, 05:51:55 PM »
That looks good mate, if I used so small a gob of JB it would drop off first time I ran it.
Good luck.
Greg
