  • June 25, 2025, 07:09:55 AM
Author Topic: Hot starting, how d'ya do it?  (Read 2477 times)
Offline phil myers
« on: August 08, 2012, 10:09:22 AM »
Doesn't seem to matter which engine/plane I'm using, after a flight, I fuel up to go straight up again, I can't get a hot engine to fire up for a good few minutes of prop flicking.. I've tried little priming (1 or 2 flicks) lots of priming 'till the fuel is dripping out the venturi, and no priming, not until the engine has cooled down will it kick into life.. is there a secret method that some kind person can share with me please?!
 Ta very much
Phil
Offline DanielGelinas
Re: Hot starting, how d'ya do it?
« Reply #1 on: August 08, 2012, 11:49:19 AM »
Hi Phil,
Two questions: 1-How hot is it in your neck of the woods?
2-Which engines are you using?
I have the same problem using the B40, fox 35 and various OS LA engines. I usually need to wait at least until I can comfortably keep my fingers on the engine. Especially the B40 which floods real easy.
I would say the easiest starting engines, when hot, for me have been the Fox 35s. Typically have to choke the fox more than on a cold start.
Now if the weather is boiling hot where you live, the wait can be longer. This is just my personal experiences; I'm sure someone with way more experience will chime in...
Good luck,
-Daniel
« Reply #2 on: August 08, 2012, 12:34:07 PM »
I have problem mostly with the OS FP.20 (iron piston), and an old ST C.35. it's nearly impossible to start when hot.  But with the OS.46LA, Stalker .61, and the OS.40VF, they usually starts with a few flips /choking the intake for prime. and one bump off the compression. (Stalker .61 & .40VF are inverted)  H^^
« Last Edit: August 08, 2012, 01:58:01 PM by Joe Yau »
Offline phil myers
« Reply #3 on: August 08, 2012, 01:10:22 PM »
Hi Daniel, this is England so not too hot! This time of year 18-25 c. Anything over 27c is a scorcher.. (sorry don't know what that is in F.)
Engines are usually a couple of Enya 25s and a 30,  SS versions ,but happens with ASP 15s and to a lesser extent OS max 35s. The OS will usually kick off after 15 -20 flips.
I'm using 5% nitro,oil 22%(increased from 18% with castor) + Enya no.3 hot plugs...
Phil
« Reply #4 on: August 08, 2012, 01:28:38 PM »
Hi Phil,
We have a double system up here in Canada, metric and Imperial... so I understand the temperature you are mentioning. Certainly not too hot. Kinda like here...
I can't comment too much on the engines you are running except for your OS .35S which should be running more cartor oil to cool it down. It does have an iron piston.
You should be running, from what I have read here, at least 26%-27% mostly castor. I run 29% all castor in my os 35s.
Good luck!
-Dan
Offline phil myers
« Reply #5 on: August 08, 2012, 01:46:34 PM »
Daniel, sorry I meant to say, that I use a higher oil fuel with the max 35 (25%) Same fuel as the Enyas but with more castor added. I may be wrong to do this but I've stopped using 'all castor' fuels.. just to much mess and the engines need a fair bit of cleaning to get rid of the 'orrible stains after a day in the field..
Phil
Offline Gary Anderson
« Reply #6 on: August 08, 2012, 03:21:40 PM »
Hi guys,
If ya use a starter, no problem, just spin the engine and she'll start. The starter saves finger, props, just can't figure why C/L group is against starters?? Most engines if ya got the proper washers and prop up front the crank will not hit the back plate. Good luck and watch out for them fingers, ya might need them??
Gary
Gary Anderson
Offline Chris Wilson
« Reply #7 on: August 08, 2012, 04:38:39 PM »
..... I can't get a hot engine to fire up for a good few minutes of prop flicking..
Take a leaf out of the Team Race guy's books, if you simply must start a hot engine again the squirt some raw fuel over the block to cool it down.
Just in case you are wondering, I have never seen one catch on fire doing this - the outside of the block simply is not hot enough.
MAAA AUS 73427
Offline Steve Thomas
« Reply #8 on: August 08, 2012, 09:42:27 PM »
That's a bit strange, Phil. I'm using Max-S 35s and SS25/30s also, with virtually identical fuel and plugs to yours. The OS (mounted inverted) just needs to be refuelled and it will start first flick when hot, without even any choking. The SS30 (mounted sidewinder) likes to be choked a couple of times, turned over a few times more, and will then start first or second flick. I don't know why yours would be any different, unless it's to do with the battery - I use a Gates cell putting out 2V.
The ones we do have a bit of trouble with are things like old OS 15s and Enya 15s. They get pretty hot, especially if they lean out at the end of the tank, feel soft in the piston, and can't seem to be hurried. A couple of extra chokes sometimes seems to help, as does the suggestion of squirting a bit of fuel on the head.
« Reply #9 on: August 08, 2012, 10:09:42 PM »
......just can't figure why C/L group is against starters?? ......
Well, there are quite a few classes that like to use diesels (and if you want to bend a rod then go ahead and use a starter if you want to), then there is the added complexity that seems to fly in the face of the 'simplicity' of CL flying , then there is that awful circle that gets worn onto spinner cones and unless you have a ringed or worn engine that lacks cold compression why would you bother?
MAAA AUS 73427
« Reply #10 on: August 09, 2012, 01:01:57 AM »
   Oh, goodness, don't dump fuel on it. We routinely fly back-to-back in practice, and I used to fly flight after flight by myself back in the Fox 35 days. Land, fuel up, go again.
   It's a matter of technique and it tends to differ from engine to engine. Many times it takes very minimal if any choking/prime. All of my PAs, for instance, took very little choking if was still hot enough. Let it cool a little bit more (i.e. fuel up and then have a conversation or a few minutes) and then it requires maybe *one* pull-through with your finger over the intake, and you had darn well better get it the first time. Of course if it cools all the way down, normal light choking.   This is pretty typical of ABC/AAC engines. The RO-Jett takes a few chokes and a few aerations when hot but is otherwise similar.
   AAC/ABC engines are prone to "shrinky piston syndrome" if you over-choke them when hot. If you overdo it, it will kick on the first back-bump but not run because it's too rich, and then dump the excess cold fuel on the bottom of the piston. It shrinks, the liner doesn't, and the whole thing feels like you unscrewed the glow plug. David's solution is to just remove the battery, flip it through 20-30 times to equalize the temps and aerate, and when you feel the compression come back, attach the battery and back-bump.
    I got dead-nuts reliable hot starts with the Fox by fueling, attaching the battery, and pulling the engine through compression with my finger over the intake until I got one bump, the removing my finger and flipping through immediately. 20 times in a row, no problem. First time I tried that with an ST46, it got so much fuel it locked up.
   This is all with inverted engines. Side mounts are harder and upright is the hardest to get started in any circumstances. They are far worse cold than hot (because hot you don't need to choke them much).
     If a Fox starts reliably hot, you can figure out how to start anything hot.
Offline Luiz Ribeiro
    • Ribeiro's Home Page
« Reply #11 on: August 09, 2012, 04:55:32 AM »
Phil
I have two Enya 30 SS and I can’t choke them when hot starting. If I want a hot start I open the needle valve for more or less ¼ turn from the position  that it was running, pull the fuel until the venturi inlet, put the ni-starter and usually it starts after the first or second flip, then I close the needle to the original position. If I choke the venturi, priming the engine, with fuel getting inside the cranckcase, it will be very hard to start it hot. This differs from engine to engine. With my LAs the difference is that I don’t open the needle valve before restarting. You have to test and discover the best way with your engines.
I liked very much the explanations of Brett Buck about the issue. We can understand better what happens.
... If ya use a starter, no problem, just spin the engine and she'll start. The starter saves finger, props, just can't figure why C/L group is against starters?? ...
I fly more RCs than CLs.  With the RCs planes I almost always use starters when starting an engine. We can do this because the planes are stronger in the nose and heavier than CL planes. With CL planes I normally don’t use starters. I have already seen people breaking the nose of their planes with starters. If the engine floods and the piston blocks, you will ruin the plane. I always use a stick to not harm my fingers when hand starting. With lighter and more fragile RC planes I don’t use starters, either.
Luiz
« Last Edit: August 09, 2012, 01:56:42 PM by Luiz Ribeiro »
Offline phil myers
« Reply #12 on: August 09, 2012, 12:21:04 PM »
Thanks to all for the comments, appreciate it. Its good to know that I'm not alone with this but even better that some of you guys have no problems with the same engines as I'm using...that means there is a way, I've just gotta find what 'll work for me. I'll try opening the nva as suggested. I do have an electric starter, hate using it, sort of cheating?, so that only comes out when I've worked myself into an exhausted frenzy..
BTW my glo starter registers 1.37v when fully charged.Getting a good orange glow so don't think thats an issue..
Phil
Offline Andrew Tinsley
« Reply #13 on: August 09, 2012, 02:45:05 PM »
Hello Brett,
Horses for courses. Here in the UK, diesel powered teamracers are regularly squirted with fuel to cool them down and then hand started! I don't do team race myself, but have seen this done so often that it must be standard practice!
Andrew.
BMFA Number 64862
